Upgrading radio
Discussion in 'Wrangler JK (2007-2017)' started by Moose2112, Feb 1, 2018.
  1. Feb 1, 2018 at 9:13 AM
    Moose2112
    Moose2112 [OP] Member
    2012 Wrangler Unlimited
    None yet
    Will this work on my 2012 JKU? I have the stock radio without uconnect.
    this is what the for sale post says about radio i would like to buy.27539978_10215344150303859_6996778872288706806_n.jpg
    Factory touch screen RER 730N Navigation am fm sirus radio cd dvd Aux USB back up camera internal hard drive and works with steering wheel controls. It has u connect for hands free Calling but will NOT stream music with Bluetooth you have to use an Aux cord. It came out of my 2010 Dodge Ram 2500 with the factory alpine system and steering controls works perfectly
    TIA
  2. Feb 1, 2018 at 10:39 AM
    I think that unit only work up to the 2010 or 2011 wranglers
    JKBob 25 and Bob like this.
  3. Feb 2, 2018 at 6:13 AM
    Moose2112
    None yet
    ok thanks for the quick response
  4. Feb 2, 2018 at 6:14 AM
    Moose2112
    None yet
    do you know which OEM radio would work?
  5. Feb 2, 2018 at 8:23 AM
    I'm fond of the 430n, as it's a Garmin based navigation and gives street views, elevations, and such. You shouldn't have a hard time finding a good used one. Also has a built in hard drive for storing music.
    aggrex, JKBob 25 and Moose2112 [OP] like this.
  6. Feb 2, 2018 at 9:10 AM
    Moose2112
    None yet
    Thanks. is that a plug and play radio, or do i need a security code and have it flashed?
  7. Feb 2, 2018 at 9:21 AM
    It's plug & play, but make sure you get one with a security xode
  8. Feb 2, 2018 at 9:21 AM
  9. Feb 2, 2018 at 12:06 PM
    Okay Chris, Ya'll have my interest now when you say Garmin based GPS. Can you set points on a map when you are on a trail to map it out, label it, and save it for later?
  10. Feb 2, 2018 at 12:58 PM
    I'm not sure. I'll have to check and see if it has this option.
  11. Feb 2, 2018 at 5:03 PM
    Moose2112
    None yet
  12. Feb 2, 2018 at 7:08 PM
    2" Superlift kit. 315/ 70/17.
    Yeah....same here. Interested in this also. If you could do as OFFGRID asked. That would be really sweet to have. Also, I have Sirusxm. And not crazy about giving that up.
    My subbed.
  13. Feb 2, 2018 at 7:37 PM
    The 430n has the SirusXM too. I'll check it out tomorrow, as that's a feature I haven't messed with.
  14. Feb 3, 2018 at 3:29 PM
    Ok....Did a little screwing around today, and I see where you can set POI's, but not sure about tracking back. I'll have to check the manual. POI's might be only for ones pre programmed into the Map software, and I haven't updated since I got the jeep.
  15. Feb 3, 2018 at 7:24 PM
    Yeah same here. I did read the manual. Gonna have to check it out again. Don't remember what it said about this. But I will report back.
  16. Feb 5, 2018 at 12:21 PM
    Billy1234
    Billy1234 Well-Known Member
    William
    2011 jeep wrangler
    None yet
    I’m in the same boat I need a Radio I don’t like the one that’s in the Jeep now I’d like a touch screen with the Nav like @OFFGRID posted I’m looking for the same thing
  17. Feb 10, 2018 at 11:57 AM
    Moose2112
    None yet
    will this one work with a 2012 JKU?
    TIA
  18. Feb 10, 2018 at 12:36 PM
    Moose2112
    None yet
    does the 430n stream music via bluetooth?
  19. Feb 10, 2018 at 12:58 PM
    Moose2112
    None yet
    if i have the res radio, do i have uconnect? want to be able to plug and play with then 430n.
  20. Feb 10, 2018 at 1:44 PM
    Yes.
    If you have the Microphone in the upper Left hand near the driver side grab handle, then you have the Uconnect system and it will be Plug & Play. What model radio are you asking about? I don't see it in the pic you posted.
