Upside down hitch!!
Discussion in 'General Jeep Discussion' started by JeepMafiaMama, Nov 14, 2016.
  1. Nov 14, 2016 at 6:01 PM
    JeepMafiaMama
    JeepMafiaMama [OP] Well-Known Member
    Lisa
    Central ny
    The previous owner of my jeep has the hitch on upside down!! Now I beat the shit out of it w\ a hammer every which way but loose apparently!! It was great fun...but I'm outta ideas??? (The ball sits up way to high for the trailer!!)... Jus tryin to get the wood done!!
  2. Nov 14, 2016 at 8:49 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    Ok...I am not quite picturing this....any photos?
    :worthless:
  3. Nov 15, 2016 at 4:26 AM
    JeepMafiaMama
    Lisa
    Central ny
    Not the whole hitch...I can't get it out to turn it around...
  4. Nov 15, 2016 at 11:03 AM
    Pull the pin, then pull out the hitch. . . Just kidding. Try spraying it with liquid wrench at both ends of the square tubing i.e. where it slides in and on the back side. Strap to a tree and pull. Sounds like you have a lot of corrosion. Good luck.
  5. Nov 15, 2016 at 2:51 PM
    JimBeam
    JimBeam Active Member
    JB
    1993 XJ
    Or PB Blast
    I like the strap to a tree idea
  6. Nov 15, 2016 at 3:32 PM
    JeepMafiaMama
    Lisa
    Central ny
    Thanks for the insight boys. I'll have to try it this wknd with the p.b. blaster.
  7. Nov 26, 2016 at 8:23 AM
    Pulling a properly strapped small trailer full of yard waste or mulch might be able to free up a rusty hitch receiver plus PB blaster or WD40
  8. Nov 26, 2016 at 11:37 AM
    JeepMafiaMama
    Lisa
    Central ny
    Sounds alil less riskier then the strappin to a tree idea...my fuckin luck I'd rip the whole back axle off my jeep if I strap her to a tree ...and after laughing n swearing a whole lot I'd prally cry!! Someday when I can see my yard again I'll try that. Ty
