Water getting into Jeep from channel above door
Discussion in 'Wrangler JL (2018+)' started by Buddy3k, May 31, 2020.
  1. May 31, 2020 at 2:15 PM
    Buddy3k
    Buddy3k [OP] Member
    2020 Wrangler 2 door Sport soft top
    Steps, front and rear receivers, trailer light wiring
    Its been raining here a lot in coastal NC. When it is raining and I open the door to get in my Jeep, the channel above the door funnels the water into the floor board and it pours on my legs as I get in. Anyone else have this problem? Suggested fixes?
  2. May 31, 2020 at 2:29 PM
    You could try some weather stripping that is available at a local hardware store.
  3. May 31, 2020 at 3:14 PM
    Buddy3k
    Buddy3k [OP] Member
    Ill have to look into that. athanks for the reply.
  4. May 31, 2020 at 4:04 PM
    Since it’s a new JL see if the dealer has any suggestions for the channel holding water. Don’t have a soft top to compare but I guess it’s good that you haven’t mentioned about water leaks inside the Jeep.
  5. May 31, 2020 at 8:10 PM
    Buddy3k
    Buddy3k [OP] Member
    Yeah no water leaks when the doors are closed. Although I don't suggest going through a carwash with a soft top. I was mostly wondering if anyone else had the same problem.
