Wet floors, no rain
Discussion in 'Wrangler JK (2007-2017)' started by NoBailing, Jul 28, 2019.
  1. Jul 28, 2019 at 12:01 PM
    NoBailing
    NoBailing [OP] Member
    It's been very dry over the past few days, but after returning from a camping trip and going to shake sand out of the front mats I noticed the floor boards were wet on the drivers and passengers sides. AC was on most of the ride home and I'm wondering if that could be related since there was no rain.
    Anyone run into this and have a solution?
    2008 JKU...
  2. Jul 28, 2019 at 12:56 PM
    A/C takes the moisture out of the air when in operation. Look underneath the dash for any signs of leaking. Check and remove any rust from that condensation.
  3. Jul 28, 2019 at 2:14 PM
    The condensate tube could be clogged with debris blocking the drainage of water during a/c usage. Carpets should be removed to dry and prevent mold or mildew.
  4. Jul 28, 2019 at 6:31 PM
    Camping = possible dirt dobber nest in a/c drain line
  5. Aug 10, 2019 at 9:50 AM
    NoBailing
    An update on the situation here... my mechanic used his air compressor to blow out the a/c drain line and said that did release a good amount of water. However, the mats still had condensation under them when I ran the a/c. He did it again, but still have wetness under the mats with a/c. Wetness is still only an issue on days I use the a/c, leaks from rain dont seem to be an issue. Anyone have an idea for the next thing to try?
    TJ_abuser likes this.
  6. Aug 10, 2019 at 10:07 AM
    Leave the carpets out for now and crack open a drain hole. When the drips start zero in on the source under the dash. Keep us updated
    TJ_abuser and JKBob 25 like this.
  7. Aug 10, 2019 at 10:19 AM
    Yep what aggrex said sounds like could be a cracked drain pan or something fell down in it and blowing it out just pushed it out of the way temporarily.
  8. Aug 10, 2019 at 6:24 PM
    NoBailing
    Removed driver seat carpets, ran a/c a solid 15 minutes, no drips in the cabin but no draining under the chassis either. Turned out the carpets were actually dripping wet underneath. I'm planning to leave them out to dry until it rains this Tuesday so I can try to find water coming in then.
  9. Aug 10, 2019 at 7:59 PM
    Welcome @NoBailing .
    Jumped on this thread cuz a friend had a moisture issue. Turns out....wasnt a bad thing...And..Wrong forum. :cool:.
    Sorry...:anonymous:. Sorry dude. I can't help,with your issue....ummmm.
    TJ_abuser and aggrex like this.
