What is with all these wires?
Discussion in 'Electrical' started by SactoDave, Feb 17, 2020.
  1. Feb 17, 2020 at 8:37 PM
    SactoDave
    SactoDave [OP] New Member
    2002 Wrangler TJ X
    2” dealer lift
    First Jeep. 2002 X. Are either of these normal?
    1. Wires coiled under driver’s floor mat:
    2. Cut wires behind driver’s seat:
  2. Feb 18, 2020 at 2:51 AM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    I could be wrong but it looks like wiring from a amp and subwoofer set not sure tho maybe someone else can chime in.
  3. Feb 18, 2020 at 2:52 AM
    Them wires don't look "normal". Trace each wire back to where it connects to before removal. Same procedure for the wires behind the seat which appear to enter the jeep via drain hole. Aftermarket stereo as @Billy1234 mentioned seems logical for the rats nest of wires.
  4. Feb 18, 2020 at 6:52 AM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Red one is definitely power for a amp and blue looks like the switch power for it also. Check the battery and behind the radio. The blue wire is prolly behind the radio the red goes to the battery.
  5. Feb 18, 2020 at 6:57 AM
    kowdog
    kowdog Member
    Steven
    89 YJ
    Converting to 91 4.0L 5-spd. Bought a wrecked 91 Saraha 65k miles.
    I agree, sub woofer/amp wires under floor mat. Wires behind seat look like seat belt warning/buckled harness. Are they in the rear harness? If so, could be for the upper light-bar/speakers if you have em..... Look for pink wire, for light, and speaker wires, 4 of em, 5 total.
    Billy1234 likes this.
  6. Feb 18, 2020 at 3:15 PM
    SactoDave
    2002 Wrangler TJ X
    2” dealer lift
    Thank you, All! We happen to have an intern in our shop who has a lot of work experience as a radio installer. Total confirmation and was able to identify the power supply line at the battery.8AB80834-5A56-42EF-B0F2-7ECF9E567F93.jpg
