What lift is needed
Discussion in 'Cherokee' started by 98zjHoward, May 25, 2018.
  1. May 25, 2018 at 7:53 AM
    98zjHoward
    98zjHoward [OP] New Member
    Jake
    1998 green zj 5.2
    Hey I recently purchased another zj the other day and I am going to build this one does anyone know what size lift will be needed to clear a let's say 31? If so any preference on which lift. My jeep is a 98 GC laredo
  2. May 25, 2018 at 8:23 AM
    Welcome to the site!
    98zjHoward[OP] likes this.
  3. May 25, 2018 at 8:25 AM
    98zjHoward
    Jake
    1998 green zj 5.2
    Thank ya
  4. May 25, 2018 at 8:51 AM
  5. May 25, 2018 at 8:55 AM
    98zjHoward
    Jake
    1998 green zj 5.2
    That's awesome thank you for the reply. I'm gonna definalenlty look into that lift. I bet a 2 in spacer on top of the lift with allow a 31 to clear nicely.
  6. May 25, 2018 at 9:45 AM
    Welcome! Hope to see the before pics way before the after pics....if you know what I mean ;)
  7. May 25, 2018 at 10:07 AM
    Yes before and after pics would be great. Start your own build thread. I think a 2in spacer in addition to the 3.5in springs would be too much for the stubby control arms. You would at least need to find longer control arms. At this point I would look into a Long Arm lift for it as the geometry is corrected with the long arm kit.
  8. May 26, 2018 at 7:14 PM
    Can't add more than what's already been said. As OFFGRID stated. Wouldn't recommend adding 2 inch pucks on top of a 3.5 inch springs. Youd have your hands full of steering wheel just tryin to keep it on the road. If your lookin to that extreme lift. Would definitely look into a long arm lift as mentioned. But even if you just do a 2 inch puck spring lift with your stock springs. Still gonna throw off your ride.
    Oh yeah....Welcome to the forum. Lolll. Yeah...Post up some pics. We like Jeep Porn.
