What to do with a Peugeot BA10/5 transmission
Discussion in 'Wrangler YJ Marketplace (1986-1995)' started by Buffalo Bill, Apr 24, 2020.
  1. Apr 24, 2020 at 4:40 PM
    Buffalo Bill
    Buffalo Bill [OP] Member
    Bill
    1988 JP
    I am new to Jeeps and putting a 1988 YJ together and I find I have a BA 10 transmission. I am having trouble shifting and wonder if I would be better to repair or replace it with a AX15.
  2. Apr 25, 2020 at 8:37 PM
  3. Apr 26, 2020 at 5:33 AM
    Buffalo Bill
    Bill
    1988 JP
    Thanks for the info. I find that the Peugeot BA 10/5 was only used a couple of years, I think 87 and 88. No one has any kind words for them. The jeep gets very light use and the only problem is shifting. I could live with it or fix it, I have not decided yet.
    Peugeot BA10/5
  4. May 8, 2020 at 7:29 AM
    SrdjanDV
    SrdjanDV Active Member
    Srdjan
    Hi, according to my experience, the BA 10/5 peugeot transsmission will works fine while treated with care and softly. the Aisin AX-15 transmission will performe much better for hard use and it's much stronger and reliable than the peugeot transmission.
    Nevertheless, there is one particular issue with the peugeot BA 10/5, it has a sort of pin that secures the shifter in possition, some times that pin moves from it's location and generates shifting problems.
    Take a look on that.
  5. May 19, 2021 at 9:56 AM
    Buffalo Bill
    Bill
    1988 JP
    I think i have all i need except the lower bushing for the shifter. If anyone has one, even in bad shape so i can get one made. I have put several parts in the transmission and really don't want to junk it.
