What Transmission
Discussion in 'Wrangler TJ (1996-2006)' started by LYFZGOOD, Aug 28, 2021.
  1. Aug 28, 2021 at 1:38 PM
    LYFZGOOD [OP] members
    With the Vin number is there a way that I can look up what transmission I have?
  2. Aug 28, 2021 at 4:39 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Nothing in the vin to tell you what transmission you have. 3 automatics and 5 manual possibilities. Only way I know of is to get the info off the id plate stamped on the transmission.
  3. Aug 28, 2021 at 5:34 PM
    Thanks. Ok. I know the dealer can tell me with the vin there were two 5 speed for the 4.0
  4. Aug 29, 2021 at 9:57 AM
    2 trans AX15 (Top) and AX5 (Lower) - did the attachment help you fugure it out?
    Let us know maybe a build sheet but I think this will guide you.
    aggrex and LYFZGOOD[OP] like this.
  5. Aug 29, 2021 at 11:44 AM
    Yes thanks. I’ll check it out tomorrow.
