What's the best oil for my engine?
Discussion in 'Cherokee' started by ShakyShane, Aug 29, 2019.
  1. Aug 29, 2019 at 5:50 PM
    ShakyShane
    ShakyShane [OP] New Member
    Michael
    1999 Jeep Grand Cherokee Lerado 4.0L
    Bigger tires p255 r16
    Ok so I bought my grandpa's jeep he retired years ago and let it sit for awhile. It is a 1999 jeep grand Cherokee lorado 4.0 4x4. 136,000 miles on it when I got it. It's at 138,680 miles now. I took my grandpa's advice and decided to put Castrol GTX 10w30 which is what he always used. No oil leaks or burning of oil. I check the stick once a week. Stays on full. I replaced the idler pully tensioner pully and this weekend I'm putting a new thermostat and water pump on it. Anyway I'm asking about the oil. I feel like if what's working works then that's great. But synthetic has me thinking. I use mobile one filters.
    spyder62 likes this.
  2. Aug 29, 2019 at 6:12 PM
    Welcome to the forum @ShakyShane .
    Synthetic oils wont hurt your motor. If you decide to go with one. Use the same weight the manufacture recommends. But the Castrol 10 w 30 is fine for your GC. Have fun with the forum. Buncha great people here. :jeepwave:
    aggrex and ShakyShane[OP] like this.
  3. Aug 29, 2019 at 6:17 PM
    watch out for the hype..
  4. Aug 29, 2019 at 6:41 PM
    Welcome @ShakyShane ....Looks like your grandpa had a well maintained JGC. You're taking the right steps in vehicle maintenance. I'm using Pennzoil synthetic oil / PurolatorOne filters in my vehicles. Walmart everyday low prices keeps costs reasonable. Oil+filter change intervals @5000-6000 miles and air filter @12-15K. Regular Dino Castrol GTX is a fine choice. Just follow recommended oil viscosity and you probably don't need to check it weekly if it seems to be consistent between oil changes.
    JKBob 25 and ShakyShane[OP] like this.
  5. Sep 5, 2019 at 11:47 AM
    Many Jeepers with 4.0s recommend RotellaT as it is supposed to have higher concentrations of Zinc which are good for a flat tappet engine like the 4.0.
    I currently run Valvoline 10w30 or Valvoline High mileage synthetic blend on my recently freshened up 4.0, she runs quiet.
  6. Oct 28, 2019 at 6:00 AM
    Jeeptrick
    Jeeptrick Member
    David
    2004 TJ
    What is the best motor oil to use on an 04 TJ with 160k miles?
  7. Oct 28, 2019 at 1:26 PM
    I am a big Rotella fan and use it for all my cars. Although I think they have backed off with the zinc over the years, you could look that up. Valvo is also a great oil.
