What's this piece involved in opening the door?
Discussion in 'Cherokee' started by Griff, Jun 25, 2018.
  1. Jun 25, 2018 at 8:09 AM
    Griff
    Griff [OP] Member
    2006 Grand Cherokee Laredo
    None so far
    In the door of my jeep there a piece attached to the inside door handle. When you pull the inside door handle this piece (a bent small diameter bent rod) engages the latch and the door opens
    Mine got bent and doesn't work.
    What is this piece called? I need a new one and can't seatc for it as I don't know what it's callef
    I would really appreciate sny I can get
  2. Jun 25, 2018 at 8:41 AM
    I think that part is called the door latch operating rod. If you cant bend it back into shape, it should be under $20.00 for a replacement.
  3. Jun 25, 2018 at 8:47 AM
    I would try to get that obscure part at the Jeep parts department as the cost should not be excessive. IMO wrecking yards might rather sell a complete door than have you dissasemble one for that part.
  4. Jun 25, 2018 at 11:17 AM
    Griff
    Griff [OP] Member
    None so far
    Anyone have a website I can get it from?
  5. Jun 25, 2018 at 7:34 PM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    you bend it to adjust. will need to do the new one!!
    just try it.....
  6. Jun 25, 2018 at 8:56 PM
    Griff
    Griff [OP] Member
    None so far
    I'll give it a try. But the door won't open using the inside handle. It's not a problem with the handle. The problem is in the rod or something not happenig when the inside handle is pulled. I can open the door from the outside no problem
    Any suggestions?
  7. Jun 25, 2018 at 9:18 PM
    Using plastic pry tools <$8 a set at Harbor Freight will get that inner door panel off. Then you can observe/inspect the operations of that rod+latch and either reattach/bend/replace that metal rod.
  8. Jun 26, 2018 at 7:32 AM
    That's the best option. It could simply might not be connected properly.
  9. Jun 26, 2018 at 9:22 AM
    Griff
    Griff [OP] Member
    None so far
    I had the door panel off and it connected at both ends. If you're the passenger side back seat youre out of luck because it just does not open the door from the inside. I rebent the bar and the system works fine. It just doesn't open the door.
  10. Jun 26, 2018 at 10:38 AM
    Just curious....is the child safety switch engaged or possibility involved with door latch not functioning???
  11. Jun 26, 2018 at 3:54 PM
    Griff
    Griff [OP] Member
    None so far
    I thought I had. I went out to check on the child lock and found something interesting. The tab that you move was not there. I fished around in the slot with a long screw diver. I fiddled with it a bit and
    After a bit I felt something move
    I got into the jeep and pulled the inside handle and it opened rigjt .I laughed at my stupidity for a couple of minutes
    Thank you all for helping me.
  12. Jun 26, 2018 at 7:52 PM
    Hey dude. Been there. Laughed at my stupidity too. Many times. Fun ain't it. :angrygirl:.
  13. Jun 26, 2018 at 7:55 PM
    Griff
    Griff [OP] Member
    None so far
    Yeah lol, it's never-ending thing
  14. Jun 26, 2018 at 8:19 PM
    Now lets see some pics of your jeep! :)
  15. Jun 26, 2018 at 8:43 PM
    Quick story. Was at an event. Had bought raffle tics. Lookin at first drawing winning numbrs list. Realized....I had my tics in my hand. :anonymous:. . Yeah.....it happens. Lollll. :frusty:. :rofl:.
  16. Jun 28, 2018 at 8:44 PM
    Griff
    Griff [OP] Member
    None so far
    20180609_074629.jpg here she is!! If you look in the upper left of the pic you'll see my old jeep. It is going to my daughter, next year, as her first jeep
    aggrex, chris4x4 and JKBob 25 like this.
  17. Jun 28, 2018 at 8:48 PM
    Awesome...putt'em in a Jeep as their ride. They'll never stray. Lolll. :thumbsup:.
  18. Jul 1, 2018 at 4:15 PM
    Griff
    Griff [OP] Member
    None so far
    I didn't know if she would want the jeep. My wife was going to break the news to her and see what would happen.
    As soon as my wife told my daughter I was getting another jeep. She broke in and asked "And I get the jeep he's driving now?" Lol, she was so damned excited. It was great to see.
    chris4x4, Bob and JKBob 25 like this.
