Wheel upgrade
Discussion in 'Wrangler JK (2007-2017)' started by Keith4x4, Apr 30, 2017.
  1. Apr 30, 2017 at 8:59 AM
    Keith4x4
    Keith4x4 [OP] New Member
    2016 Jeep Wrangler Unlimited Rubicon
    Largest wheel setup for a 2016 Jeep Wrangler Unlimited Rubicon without a suspension change?
  2. Apr 30, 2017 at 12:16 PM
  3. Apr 30, 2017 at 6:00 PM
    If you run Metalcloak's over line fenders you can run 37s with a spacer or aftermarket wheel. If you run flat fenders 35s with spacer or aftermarket wheel. And no change at all to the jeep 33s and maybe 35s with a spacer or aftermarket wheel.
