Where is this fluid coming from?
Discussion in 'Grand Cherokee' started by Nated0323, Jul 9, 2020.
  1. Jul 9, 2020 at 2:20 PM
    Nated0323
    Nated0323 [OP] Member
    2004 Jeep Grand Cherokee. Can anyone tell me what all the fluid is and where it’s coming from ? Looks like grease, but not sure where it would be coming from. It was only like this on the rear drivers side. Thanks
  2. Jul 9, 2020 at 4:20 PM
    Looks maybe like a wheel cylinder Check the reservoir to see if it has brake fluid or almost empty. The one picture looks like maybe the brake caliber is bad also
  3. Jul 9, 2020 at 5:06 PM
    Agreed...brake cylinder is likely the source of the wetness. Diagonal braking systems probably allowed you to make it home. Repair is not difficult.
    LYFZGOOD likes this.
  4. Jul 9, 2020 at 5:58 PM
    You are going to want a replace the brake shoes and pads when you do job and any other parts you see that is bad when you do the brake job. If you don’t know what you are doing get help it’s not really a hard job but it’s ur BRAKES!!
  5. Jul 9, 2020 at 6:57 PM
    Nated0323
    I discovered this when checking my brake pads. I thought I needed new ones bc I heard a some squeaking but all the pads have a lot of life left. Just wondering how you can that the caliper is bad? The guy from the place I bought it from said that caliper was new. But then again he supposedly replaced the bad muffler with a “new” one and this is what it looks like a few months later..
    so I’ll be paying him a visit this weekend.. thanks for the help fellas
  6. Jul 9, 2020 at 9:11 PM
    Well the pads look pretty good but the rear shoes look pretty bad even if the shoes were new they are soaked with fluid and would need to be replaced but they looked pretty bad I don’t think they are new.
  7. Jul 10, 2020 at 3:58 AM
    Nated0323
    Ok thanks. I checked the brake fluid reservoir and it’s full. I will look in to the brake cylinder and hopefully that takes care of it
  8. Jul 10, 2020 at 7:25 AM
    Was it full where you couldn’t get another drop? A little fluid goes a long ways and may make quite a mess it could be the wheel seal but with the Front brake caliper being wet with fluid I tend to believe it’s the Brake cylinder
  9. Jul 10, 2020 at 2:12 PM
    Interesting, looks like somebody replaced the calipers and brake shoes without changing brake cylinders. What a way to save money!
  10. Jul 10, 2020 at 3:54 PM
    you mean the pads the shoes looks like they have 100.000 miles on them
  11. Jul 10, 2020 at 4:40 PM
    Nated0323
    Yes the pads all look new , that’s why I didn’t change them last weekend.. the shoes are probably old but that wasn’t a concern, I’m just worried about whatever is leaking.
  12. Jul 10, 2020 at 4:49 PM
    Well if and when you find the leak fix it and then replace the shoes if not then are going to be in the dum before too long
  13. Jul 10, 2020 at 6:32 PM
    Nated0323
    Yes , I will investigate the leak this weekend. Thanks for all the help
