Where to buy center seat belt clips?
Discussion in 'Wrangler TJ (1996-2006)' started by jleebailey, May 23, 2017.
  1. May 23, 2017 at 9:37 AM
    jleebailey
    jleebailey [OP] Member
    Jim
    2000 Wrangler Sport 4.0
    Anybody know where I can get the center seat belt clip(s) that mount to the floor below the rear seat? I have no where to clip the rear shoulder harness. Just bought this 2000 Wrangler Sport.
  2. May 23, 2017 at 9:44 AM
    See if you can get the part number from the dealer, then post it here.
  3. May 23, 2017 at 12:13 PM
    jleebailey
    Jim
    From local dealer - Seat belt - part #5FX94LAZAA. $69.00 plus tax. They didn't have it in stock, but will be one day delivery.
    chris4x4 and Bob like this.
  4. May 23, 2017 at 12:16 PM
    Morris4x4center.com
    quadratec.com
    I just purchased a set for my YJ off of ebay for $38.
    chris4x4, JKBob 25 and Bob like this.
  5. Jun 7, 2023 at 2:06 AM
    JeepYJ131
    JeepYJ131 New Member
    94 YJ
    Just bought my first YJ and it only has one rear seat belt. Can anyone tell me if the rear center seat belt clips are bolted to one bolt or have individual bolts for the female end? Thanks!
  6. Jun 7, 2023 at 9:59 AM
    No longer own a YJ to confirm but if only one mounting bolt and hole exists then it may share the same attachment point. Otherwise there would be an additional mounting hole to bolt thru
    LYFZGOOD likes this.
