Why does my jeeps horn beep at random?
Discussion in 'Wrangler JK (2007-2017)' started by Boondocker, Aug 23, 2017.
  1. Aug 23, 2017 at 10:12 AM
    Boondocker
    Boondocker [OP] Member
    2007 Wrangler
    Added trailer hitch
    :redjeep:Why does my jeeps horn beep at random ?
  2. Aug 23, 2017 at 1:52 PM
    Welcome to the site!! Can you give more information about the vehicle?
  3. Aug 23, 2017 at 4:09 PM
    Boondocker
    2007 Wrangler
    Added trailer hitch
    The jeep is a 2007 wrangler. The problem started with the on board alarm going off for no reason when the jeep was parked in my garage. I stopped the alarm by pushing the unlock button on my remote. Since then the alarm beeps at random. Sometimes once every minute or so, then it is quite for a long time.
    (like when I'm at the dealer to get it fixed.)
    :annoyed:
  4. Aug 23, 2017 at 6:24 PM
    Is it an after market alarm, or OEM system?
  5. Aug 23, 2017 at 6:30 PM
    :alien: . Welcome to the forum Boondocker.
  6. Aug 23, 2017 at 7:05 PM
    Boondocker
    2007 Wrangler
    Added trailer hitch
    It is OEM.
    I had the recall on the clock spring implemented by my dealer and it did not fix the problem
  7. Aug 23, 2017 at 7:14 PM
    man....I would start with disabling the alarm system. If that solves the issue, then you know that was the cause, and can go from there.
  8. Aug 23, 2017 at 7:23 PM
    Boondocker
    2007 Wrangler
    Added trailer hitch
    I don't know how to disable the alarm system without killing the horns. I did remove the left hand horn fuse (M23) and that did disable both horns as well as the alarm system.
  9. Aug 23, 2017 at 7:27 PM
    The alarm system should have a fuse. If not, disconnect the positive wire powering it.
  10. Aug 23, 2017 at 7:35 PM
    Boondocker
    2007 Wrangler
    Added trailer hitch
    OK. I'll go look for a fuse or relay or wire. Thanks much. It will be tomorrow AM before I can get back to you.
  11. Aug 23, 2017 at 7:40 PM
    Ok. In the meantime, maybe someone else can pop in with some input
  12. Aug 23, 2017 at 8:08 PM
    What do ya need a horn for. Lol. In most cases I've found. It's either a cat, a deer, or some other animal ran out into my path, and froze. So I hit the horn. If some one runs a stop sign or a red light. What good is a horn gonna do ya. Lol. Stick your head out the window and scream at the stupid mother mocker for being a dumb ass behind the wheel. Because I can promise you. They were probably on their phone. My 2 cents. Lollll.
    Holy crap. Did I just sound like jeep Mafia Mama Lisa there. :anonymous:. It's all good.lol.
    Just sayin. o_O.
    Ok, my bad. Flip flop my quotes. Lol.
    JeepMafiaMama likes this.
  13. Aug 23, 2017 at 8:11 PM
    :playball::popcorn:
  14. Aug 24, 2017 at 8:09 AM
    Boondocker
    2007 Wrangler
    Added trailer hitch
    Well I could not find a way to disable the panic alarm without killing the horns. So, I pulled M23 again so I have no horn or panic alarm.
    I agree with JKBOB 25 that I don't need either, but I just have to have all my stuff working correctly.:sadviolin:
  15. Aug 24, 2017 at 8:59 AM
    I agree with having everything working correctly. Maybe someone else has an idea
  16. Aug 24, 2017 at 11:21 AM
    Welcome! Generally something is triggering the alarm either via motion sensor or switch triggered. Assuming the alarm is defective or perhaps shorted or has a bad ground try to disconnect the alarm from the horn system so you can retain the horn function. You should be able to test-trigger the alarm by opening a door or hood etc. then try to shut if off. Maybe the dealer that serviced the clockspring could provide a wiring diagram for the OEM alarm system. Just throwing some ideas out there.
  17. Aug 24, 2017 at 1:28 PM
    JeepMafiaMama
    JeepMafiaMama Well-Known Member
    Lisa
    Central ny
    Scary jk you got me pegged there...u sure you don't know me...
    Get yourself a megaphone Boondocker it will be way more amusing! Especially if u hit the siren button!! Seems to get ppls attention right quick! Don't amuse yourself in front of the police...(leave it alone jkbob).... They don't find it funny!
  18. Aug 24, 2017 at 6:40 PM
    I agreewithJKBOB 25 that I don't need either, but I just have to have all mystuff workingcorrectly
    I'm the same way dude. Even if i'll never use something. I still want it to work. My OCD, I guess.
    Hell yeah I got you pegged mafia mama Lisa. Na, I don't know you. But we are some what alIke. I just don't yell,and scream any more. Not worth using my time and energy on a moron.
    And oh by the way. You say some thing like "don't amuse yourself in front of the police." Did you really think I would leave it alone. :jerkoff:. Apparently....you don't know me. Lol. So how would you know about amusing yourself in front of cops? Have Personal first hand experience do we??? So we're you in your Jeep....at the park??? No, not in a dressing room at Macy's. You know Security Guards aren't real cops. You should've have run. Lolll.:notsure:
    Chris4x4 is thinking.....Finally, he's not picking on me. :rofl:
  19. Aug 25, 2017 at 7:30 AM
    JeepMafiaMama
    Lisa
    Central ny
    I totally knew jk would have something to say!! :stirthepot:...my 1st (which was also my last) car didn't have a horn so I DID use the megaphone...maybe not always appropriately :censored:. Then I got a half hearted STERN talking to by d :dancingbacon:and they took my toy...they always took my good shit when I was a kid:rant:. No weirdness jk...your shot! ! You get points for imagination tho...:flipoff:
  20. Aug 25, 2017 at 7:28 PM
    What did you do. Stick your head, with the megaphone, and yell beep beep. Or should a say. Jeep Jeep. :)
