Will a 4" suspension lift work with a 1" body lift?
Discussion in 'Wrangler TJ (1996-2006)' started by Wilder, Feb 19, 2018.
  1. Feb 19, 2018 at 1:53 PM
    Wilder
    Wilder [OP] New Member
    Chris
    99 tj sport 6cyl
    Looking to replace my 3" suspension lift on jeep I bought last year. Will a 4" suspension lift work with a 1" body lift?
  2. Feb 19, 2018 at 4:23 PM
    welcome to the site! What are you looking to achieve?
  3. Feb 19, 2018 at 5:00 PM
    Welcome! Why not run the proposed lift first then the body lift if needed for your specific needs.
  4. Feb 19, 2018 at 5:54 PM
    Yes they will work together, but what is your end goal and is it on the TJ that you have on your profile?
  5. Feb 19, 2018 at 7:47 PM
    Welcome to the forum @Wilder. I agree with above posts.
    When i bought my JK. I was also looking to add a body spacer kit. And when I saw the issues and extra work that went into a body spacer kit. I decided not to. Figured I was better off with just a suspension lift and add on to that if I wanted more lift. In the future. Just my experienced 2 cents.
  6. Feb 20, 2018 at 4:53 AM
    mudbug85603
    mudbug85603 Active Member
    Jim
    Upstate SC
    If your intent is to run 35" tires....There's more to do than just get enough clearance for the tires. Things like steering upgrades, brake upgrades, possible axle upgrades, regearing......It can get expensive.
