Will a bad battery keep vehicle from running once started?
Discussion in 'Cherokee' started by Raccoon, Apr 24, 2018.
  1. Apr 24, 2018 at 7:01 PM
    Raccoon
    Raccoon [OP] New Member
    1999 Cherokee
    Yesterday while driving, my Jeep died. Seemed like it was probably the alternator. After getting towed home, I had the alternator and the battery tested. The battery is bad. The alternator is good. So, can a bad battery cause a running car to die if the alternator is good?
  2. Apr 24, 2018 at 7:39 PM
    Welcome! If the battery is bad and the voltage drops too low your jeep could stall. Alternators stressed from extended attempts to charge the dead or dying battery may also be damaged.
  3. Apr 24, 2018 at 8:03 PM
    Welcome to the forum @Raccoon. As aggrex stated. A bad battery will cause stress on alt. And yes. A bad battery will cause jeep to do many :censored:ed up crap. Replace battery and go from there. If check motor light brightens up your dash and day. Get codes. Post here. And we have many code readers here that can help. Hope this helps. Post up your findings so we might be able to help. Good luck
  4. May 3, 2018 at 6:25 PM
    Chillmo
    Chillmo Well-Known Member
    Drew
    Ostrander
    Yes. Battery could have more then one dead cell.. Mine had one dead cell. Would barely start but then die, but battery and alternator tested fine with electronic testers.. My boss showed me how to test each cell with hydrometer and one was dead.. New battery, problem solved ..
  5. May 3, 2018 at 6:38 PM
    Welcome aboard!
  6. May 4, 2018 at 6:20 AM
    This would be cool to know. Please post a tutorial up. How did you test each cell?
  7. May 4, 2018 at 7:53 AM
    OFFGRID[QUOTED] likes this.
  8. May 4, 2018 at 8:37 PM
    Chillmo
    Drew
    Ostrander
    I didn't know about the multi meter way.. But with a hydrometer, his open th e caps on the battery suck up some fluid with the hydrometer and the arrow points in the green or red.. Or good /bad depends on how it's marked. Squirt it back in and check the next hole till done. If any are bad, replace battery.
    OFFGRID likes this.
