Window and door locks not working when passenger door is open
Discussion in 'Cherokee' started by 911 SUPERVISOR, Aug 2, 2019.
  1. Aug 2, 2019 at 12:53 AM
    911 SUPERVISOR
    911 SUPERVISOR [OP] Member
    Danny
    1999 grand cherokee laredo
    i have a 1999 grand cherokee laredo, I just installed a new regulator in the passenger front window. Everything works however when the passenger door is open window or door locks will not work. This started about 6 months ago. I pulled the plug loose from the bottom of the door where the wiring comes into the door and it look ok there. Any ideas?
  2. Aug 2, 2019 at 4:58 AM
    When the issue appears is it intermittent or can it be triggered? Sometimes wires get pinched or have small fractures etc
  3. Aug 2, 2019 at 7:38 AM
    YOU said " it look ok " sorry that is not a real test.
    Yes it is there where the wires often fail - but more testing.
    Can you use a test light, DVOM and a wiring diagram?
    Passenger windows work OK?
  4. Aug 2, 2019 at 11:00 PM
    911 SUPERVISOR
    Danny
    IT IS ANYTIME YOU OPEN THE PASSENGER SIDE FRONT DOOR.
  5. Aug 2, 2019 at 11:01 PM
    911 SUPERVISOR
    Danny
    YES I CAN USE A TEST LIGHT
  6. Aug 2, 2019 at 11:01 PM
    911 SUPERVISOR
    Danny
    YES IF THE DOOR IS CLOSED WINDOWS AND DOOR LOCKS WORK JUST FINE
