Wiring Harness
Discussion in 'CJ' started by Thomas85, Feb 12, 2022.
  1. Feb 12, 2022 at 3:14 PM
    Thomas85
    Thomas85 [OP] New Member
    Thomas
    85 CJ7 with Chevy 350
    Chevy 350
    I got a 85 CJ7 with a SB Chevy 350. Need some advice on a wiring harness that would work with this set up. Any suggestions or part numbers, manufacturers, etc. thanks in advance.
  2. Feb 12, 2022 at 11:41 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Painless 10150 harness is pretty complete, but also pretty expensive. Is the 350 Carb or FI? Painless harness isn't engine specific and doesn't have the FI or ecm wiring. I have a '95 TBI 5.7. The wiring harness consists of stock YJ, ecm and harness from the Chevy 1 ton donor and additional wire that I've added for stuff like the Accel coil, check engine light and Autometer gauges. I also ran a new tach wire to HID and replace the stock tach with Autometer. Seemed a lot easier than trying to get a 6 cyl tach to work with the V&. Most of the factory harness can be shortened or lengthened to work.
  3. Feb 13, 2022 at 12:31 AM
    Thomas85
    Thomas
    Chevy 350
    I really appreciate it. Yeah it’s carb. I’m nowhere near a gear head or even wiring guru. My buddy and I said how hard could it be so I said, lemme get a second opinion. Everything seems expensive on this ole girl, but she’s worth it. I really appreciate you taking the time to respond.
