Wiring up new brake lights
Discussion in 'Wrangler TJ (1996-2006)' started by Adam39601, Dec 25, 2019.
  1. Dec 25, 2019 at 7:53 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    Got some led brake lights from Santa got 5 wires 2black red,bro, white. Can anyone tell me what wires go to what on my 01wrangler thanks
  2. Dec 26, 2019 at 12:18 PM
    Did Santa send you instructions for those? As led lights do not require as much juice as conventional lights do. you could get a test light to find out what wire does what. Usually red is the hot line and black is ground. Other colors should be the turn signals.
    JKBob 25, Bob and aggrex like this.
  3. Dec 28, 2019 at 4:16 PM
    Red, Brown & White should be the Brake, Turn, & Reverse. The Black wires are ground. Might be best to contact the company they were purchased from to see if they have installation instructions.
