Wonky speedometer on 2002 Liberty Sport-- need help
Discussion in 'Liberty' started by lbnj, Sep 22, 2018.
  1. Sep 22, 2018 at 7:11 AM
    lbnj
    lbnj [OP] New Member
    2002 Liberty Sport
    Speedo bounces around erratically. Driving at constant speed, and it will drop back down and return to approximate speed. When driving around 25-30 mph, I feel a clunk/ downshift at odd times. Had speed sensor checked--it's ok. Had speedo gauge checked, and its ok. Mechanic is thinking may be electrical issue--odometer doesn't measure accurate mile (about .2 short every mile).
    Any ideas? Would welcome any help you can offer-- I know NOTHING about engines, but don't want to spend extra $$$ having mechanic checking all the wiring in the Jeep if that's not the problem. Thanks!
  2. Sep 22, 2018 at 7:42 AM
    Welcome to the site! I cant help, but someone should pop in with some info soon.
  3. Sep 22, 2018 at 8:29 AM
    to start SCAN system- use a SCANNER post ALL codes...
  4. Sep 22, 2018 at 9:39 AM
    Almost need this as a sticky post.
  5. Sep 22, 2018 at 9:55 AM
    Welcome! Not sure whether '02 Liberty still use speedometer cables but I've seen worn out cables or cables that need some lube have similar issues.
