Won't take fuel
Discussion in 'CJ' started by fitster, Jun 30, 2017.
  1. Jun 30, 2017 at 7:32 AM
    fitster
    fitster [OP] Member
    Dave
    La Grange TX
    79 CJ7 401 Auto, Dual lockers
    The 79 CJ7 I got doesn't want to take fuel at the pump. It takes forever to get a coupla gallons in. It has the optional 20gal plastic tank. The fill hose looks fine, if kinda small. This normal?
  2. Jun 30, 2017 at 9:28 AM
    Welcome! Check to see if there are any blockages or kinks in the fill hose connection to the tank.
  3. Jun 30, 2017 at 9:38 AM
    Welcome! Hang tight because there are plenty of CJ owners on this forum that can probably help with this issue. Maybe not related but a locking gas cap may prevent simple stupid vandalism.
  4. Jun 30, 2017 at 2:05 PM
    JEEP # 5
    JEEP # 5 Well-Known Member
    MARK
    2014 BLACK & GREY
    Welcome Fitster. I have a JK now but had a CJ7 in the past. When pumping in, the air needs a place to come back out. Make sure the airline or hole is clear. It will stop pumping quick if the pressure can't escape.
  5. Jun 30, 2017 at 6:33 PM
    Welcome fitster. Awesome Forum. Have fun with it.
  6. Jun 30, 2017 at 7:34 PM
    Definitely check your hoses from the tank to the filler. Many times people replace them with straight hose and bend it. You should have 2 hoses, a big filler and a smaller bent hose. This will cause your symptoms. If you need to, order the correct hoses from quadratec or Morris 4x4 or the like. They are L shaped. Having an after market tank the factory hoses may have been too short. Use the factory hoses and extend them using copper plumbing pipe and hose clamps if needed. Dealing with PO's jerry rigging can be a nightmare.
  7. Jun 30, 2017 at 8:00 PM
    What OFFGRID said and previous posters. Air needs to escape. And In most cases, it's not your fault. It's an issue the PO created. Trace your lines and patience will be your friend. Good luck dude.
  8. Jul 1, 2017 at 6:16 AM
    fitster
    fitster [OP] Member
    Dave
    La Grange TX
    Thanks everyone. I took the tank out (stock factory option) and the hoses were clear, but weird. The fill hose has adapters at the fill and then the tank with a larger hose between,??? From the replies, I guess it isn't normal, so I've ordered stock hoses and hopefully that will correct the situation. Then time to move on to the ARB lockers that have been disabled.
  9. Jul 16, 2017 at 4:09 PM
    fitster
    fitster [OP] Member
    Dave
    La Grange TX
    Well, put the tank back in with new hoses, being sure there were no kinks or weird stuff, it takes gas, but VERY slowly. Won't even go to the first click on the gas pump. But I guess it is what it is.
  10. Jul 17, 2017 at 9:02 AM
    That is still not normal. The tank should have another vent hose on the driver side going up to a charcoal cannister under the hood. I have disconnected mine and plugged it and I can still fill as fast as the pump will go. Maybe the vent at the filler is restricted. If you get bored disconnect the smaller hose and see if you can easily blow into it. I have never heard of a factory option for a 20gal tank, but that is not to say there weren't any. I have only seen aftermarket poly gas tanks. If yours was metal it likely is original. I will say that the nozzle makes a difference. Here in Texas we used to have a these reclaiming nozzles that would reclaim the gas fumes that came from the tank. My CJ did not like those and I would have to pump very slowly to fill it up. Now we have gone back to the old style nozzle from the 70s and it works great. Good luck.
  11. Jul 17, 2017 at 12:36 PM
    fitster
    fitster [OP] Member
    Dave
    La Grange TX
    All the hoses are new. I think you're right about the nozzles, I'm just up here in La Grange and we still have the funky new nozzles. Maybe I'll try one of the old stations in town.
  12. Jul 17, 2017 at 7:06 PM
    Hey you are close. I go through there all of the time to see my parents in Burnett and stop by Hidden Falls. That area close to you on Highway 71 with the 2 gas stations where is slows down to 55. The shell has the old back to new nozzles.
  13. Jul 30, 2017 at 8:42 AM
    fitster
    fitster [OP] Member
    Dave
    La Grange TX
    Well as it turns out, that Shell station is where I got it to take a little fuel, however slowly. But I just tried the new Murphy's at the Super Wally and it would stay filling using the first click on the pump handle and shut off when full!! So I'm happy. Guess it is a pump handle thing.
  14. Aug 5, 2017 at 4:39 PM
    2008jkrubicon
    2008jkrubicon Member
    Paul
    Lifted 2008 2 door JK Rubicon
    35s on 3.5 lift, rugged ridge front and rear bumper with Warren winch. K&N air filter, slotted disc brakes, Borla duel exhaust, Grote headlights
    This happened to me and it ended up being the evap canister had a crack.
