Wrangler JL Side Steps / Rock Sliders
Discussion in 'Wrangler JL (2018+)' started by csuviper, Aug 2, 2018.
  1. Aug 2, 2018 at 7:51 AM
    csuviper
    csuviper [OP] Tundra Guy Moderator
    Brian
    Colorado
    18 Jeep Wrangler JL Rubicon
    Will be mostly stock
    Starting the search to replace the standard Rubicon rock rails with something that is more of a step for my son to get in and out.
    What options are out there?
    What are the good manufacturers?
  2. Aug 2, 2018 at 8:09 AM
    Check out the nice steps that @JDMcQ used and his issue with a broken mount bolt
  3. Aug 2, 2018 at 8:12 AM
    csuviper
    Brian
    Colorado
    Thoughts on the following?
    N-Fab full length RKR side rails
    ACE JL Rock Slider
    JCROffroad Classic Rock Slider
    JCROffroad Crusader Rock Slider
    Body Armor Rock Crawler Side Steps - JL-4121
    Rock-Slide Engineering Rock Sliders
  4. Aug 2, 2018 at 8:19 AM
    csuviper
    Brian
    Colorado
    Ok looks like he got the JCROffroad Classic Rock Slider and had an issue with the factory bolt being cross threaded. Hopefully i dont have that problem.
  5. Aug 2, 2018 at 8:44 AM
    RubiconFreedom
    Nor-East Uni-Stat
    After careful searchings ourselves, we found that the Tyger "Star" side steps are more to our liking.
    The main draw to this type of side step is that it mounts in double point locations. As one could eventually cause body damage if there's no connecting point from the chases to the body or vice versa. Seen and heard horror stories of those who used just the chases mounted side step, flex on the trail and end up damaging the rocker panels etc.
    csuviper [OP] likes this.
  6. Aug 2, 2018 at 4:59 PM
    boondoc89 Well-Known Member
    Post up a vote poll!! If I had to choose from the ones you listed... I think I'd take the ACE rock sliders. They look good. If they only hooked up to the rocker panels then that would sway me in another direction but I like simple. You could always weld a step plate on them at a later date If the bars aren't working.
  7. Aug 3, 2018 at 9:50 AM
    csuviper
    Brian
    Colorado
    Ok i have a source where i can get the JCR for around $500 and the Body Armor for around $350. JCR is in stock and the Body Armor is not.
    Anyone have the Body Armor on their JK?
  8. Aug 3, 2018 at 2:46 PM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    Not sure if it’s the same company but I bought some body armor for my Toyota years ago and it was a mistake. Parts were sold as new and clearly were not, missing hardware, bolts didn’t line up. It was a pain in the ass. Once again tho, not sure if it’s the same company.
  9. Aug 3, 2018 at 8:58 PM
    csuviper
    Brian
    Colorado
    Add on removable steps for the Rubicon rock rails would be awesome. Any chance they make them?
    Found some N-Fab removable steps for rock sliders. Not a fit to the rubicon rock rail though.
  10. Aug 3, 2018 at 9:15 PM
    csuviper
    Brian
    Colorado
    Might go with the ace sliders as they are only $449
  11. Aug 3, 2018 at 9:26 PM
    csuviper
    Brian
    Colorado
    These LOD Rock sliders are awesome but $$$$
  12. Aug 4, 2018 at 10:28 PM
    csuviper
    Brian
    Colorado
    JCR look like they have much better mounting.
  13. Aug 5, 2018 at 9:43 AM
    RubiconFreedom
    Nor-East Uni-Stat
    Just one of our concerns on the Jeep, would the if the sliders have a side impact standard as it would seem a bit pointless to go with a slider or side steps that don't protect one from a side impact. Would be something that needs to be added into the decision of which side step/slider you consider.
  14. Aug 9, 2018 at 9:48 AM
    agelotti
    agelotti Member
    Anthony
    2018 Wrangler Unlimited JL Rubicon
    None
  15. Aug 11, 2018 at 9:44 PM
    csuviper
    Brian
    Colorado
  16. Aug 12, 2018 at 11:45 AM
    agelotti
    agelotti Member
    Anthony
    None
    Understand, they are pricy.
  17. Aug 14, 2018 at 12:32 PM
    csuviper
    Brian
    Colorado
    Just purchased the classic sliders with powder coat directly from JCR. $619 to my door. 15-20 days.
