Wrangler power steering
Discussion in 'Wrangler YJ (1986-1995)' started by Jeepkid, Jun 16, 2018.
  1. Jun 16, 2018 at 3:35 PM
    Jeepkid
    Jeepkid [OP] Member
    So. I know what I need to add power steering to my jeep. Questions is what vehicles can I pull those parts from if I go to a junk yard?
  2. Jun 18, 2018 at 7:04 AM
    Find a jeep the same years (CJ, YJ, TJ), motor (I4 or I6), and same belt drive system (serpantine belt or V-belt). You will need the power steering pump and brackets and blots that mount it, and if a serpentine belt you will need the one that accomadates power steering (it is longer). If your jeep has the older v-belts you'll need a powersteering belt. You will need the steering gear box and pressure and return hoses as well. The pitman arm is likely larger diameter on the power steering gear box than manual box so you will likely need that too.
    Bob and aggrex like this.
  3. Jun 18, 2018 at 6:43 PM
    Jeepkid
    Jeepkid [OP] Member
    Awesome! i had the hardest time trying to find this info, thanks a million.
