Wrong Driveshaft ? Possibly Wrong Front Axle ?
Discussion in 'Cherokee' started by TinyInkognegroT, Aug 14, 2019.
  1. Oct 6, 2019 at 5:37 PM
    #21
    TinyInkognegroT
    After doing some more research, do you think my problem could be a bad vicious coupler in the 249 transfer case ? I know it could be expensive, but wouldn't that be easier to buy that and replace that part rather than to pull and replace my whole transfer case ?
  2. Oct 7, 2019 at 6:07 AM
    #22
    Bad control arm bushings could allow the caster of the front axle to change under load..... could that damage your front driveshaft?... I don't know.
    Your driver side bushing looks out of wack.
    Doubt the "wrong" front axle was swapped in. I could put a ZJ Dana 30 in my XJ (it would bolt right in, but not that I would want to since it's a low pinion) and it would work just fine. I am using a 99 XJ Dana 30 in my 93 XJ. But like you I am not finding much info regarding the difference between in front driveshafts. I have seen references to driving without a front driveshaft could damage the VC.
  3. Oct 7, 2019 at 8:32 AM
    #23
    TinyInkognegroT
    Sounds like my next focus is the front suspension...
  4. Nov 9, 2019 at 4:42 AM
    #24
    TinyInkognegroT
    I'm wanting to put in another front driveshaft in but I'm afraid of it breaking on me again... Never figured out the cause of the other 2 breaking..
  5. Nov 9, 2019 at 6:11 AM
    #25
    Oh whats another shaft again? Whats the history on the first two shafts? Used parts? Perhaps you will have better luck this time.
  6. Nov 9, 2019 at 9:00 AM
    #26
    TinyInkognegroT
    Not sure why the first two broke. I got a video of the second one bending as I'm going through gears. They always seem to break on the CV end that attaches to the front axle. But you're right, maybe I should pull one from the scrap yard and take it to our local driveshaft shop to have it balanced and things
