17 inch wheels from 2008 Wrangler on a 2012?
Discussion in 'Wrangler JK (2007-2017)' started by tomrr, May 29, 2021.
  1. May 29, 2021 at 7:29 AM
    tomrr
    tomrr [OP] Well-Known Member
    Tom
    2012 Wrangler JK
    Found a good deal on 5-17 inch 75th anniversary wheels off a 2008 wrangler. will these fit a 2012 JK WRANGLER ??
  2. May 29, 2021 at 11:02 AM
    Should be a perfect fit. Same bolt pattern 5 x 127
  3. May 30, 2021 at 4:35 AM
    tomrr
    Tom
    2012 Wrangler JK
    I there any of telling if theses wheels have TPS Seniors ? 192282148_301628968337083_8959314116618294597_n.jpg
  4. May 30, 2021 at 11:04 AM
    Hard to tell for sure from the pics but you might be able to reuse your old ones.
    tomrr[OP] likes this.
  5. May 31, 2021 at 4:31 AM
    tomrr
    Tom
    2012 Wrangler JK
    Thanks for the reply. If not would it hurt to run without TPS ? I am thinking the dash tire light would stay on. I wanted to keep my stock tires and wheels together. and not sure if I want the cost of new TPS AND reprograming them .
  6. May 31, 2021 at 9:04 AM
    tomrr
    Tom
    2012 Wrangler JK
    Well I took out air valve and pushed a thin wire down Valve stem and it stop, Was told that is a way to check for A TPS .
  7. May 31, 2021 at 1:33 PM
    Most modern vehicles (2005 and up) come with TPMS these days so the odds are your used wheels will have them unless the previous owner removed them.....ask
  8. Jun 1, 2021 at 4:48 AM
    tomrr
    Tom
    2012 Wrangler JK
    I did and and got no response
  9. Jun 1, 2021 at 8:12 PM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Good enough as it is
    Tpms sensors are not required for your vehicle to run as long as you can stand looking at the dash light being on. You can turn the light off using a Jeep reprogrammer device like a Superchips Flashcal.
  10. Jun 5, 2021 at 10:59 AM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    @tomrr - just a further thought on TPMS sensors - They switched from 315 MHz to 433 Mhz in 2013, so that won't be a problem for your application. However most sensor batteries only last for around 10 years anyway, so you'll soon enough end up buying new ones down the line one way or the other.
