1970 CJ5 Ignition wiring problem
Discussion in 'CJ' started by rangemaster, Aug 10, 2019.
  1. Aug 10, 2019 at 6:15 PM
    rangemaster
    rangemaster [OP] New Member
    1970 CJ5
    This Jeep has long been my very reliable hunting vehicle, until last season when a new problem cropped up. You'd be bouncing along a dirt road when all electrical that required the key to be on would cut out, including the engine. After some roadside fiddling, I found that wiggling the under dash wiring would revive it. I replaced the ignition switch, believing it to be the culprit, to no avail.
    Narrowing it down, there's something in the wiring loom that connects to my ignition switch that will kill all keyed electrics if it is moved, or bumped in a certain way.
    Here's a video I shot showing exactly what I'm talking about:
    https://www.youtube.com/watch?v=5RHy8DTRZFk
    Has anyone ever experienced this? Does anyone know where to start?
    Thank you for reading this.
  2. Dec 21, 2019 at 9:46 AM
    Drd88
    Drd88 Active Member
    Dan
    Silver creek new york
    79 cj 5/2000 wrangler
    360amc Borg Warner t-18 trans
    Have you fixed this probably already?I see post is from August
  3. Dec 22, 2019 at 4:15 PM
    rangemaster
    1970 CJ5
    I did. It ended up being a bad wire coming off the voltage regulator. So I strung a new wire and spliced it into the ignition switch and all was well.
