1972 Wagoneer tailgate window motor
Discussion in 'Other Jeep Vehicles' started by Moparman, Sep 8, 2016.
  1. Sep 8, 2016 at 12:15 PM
    Moparman
    Moparman [OP] New Member
    Roy
    1972 Jeep Wagoneer
    I need to replace the tailgate window motor on my 1972 Wagoneer. I ordered a Cardone model 42-22 which said it fit a 1972-77 Wagoneer. It is not even close in bolt pattern and design. The motor that is in it is an American Bosch model 581 178A. I can't find this anywhere. Any ideas?
  2. Sep 8, 2016 at 1:32 PM
  3. Sep 9, 2016 at 4:29 PM
    Moparman
    Roy
    1972 Jeep Wagoneer
    No. No other numbers. After researching I think the regulator in the Wagoneer is manual. all diagrams I can find show the electric motor mounts on the left side of the regulator. There is no place to mount the regulator on the left side. the only holes in this regulator is in the center between the 2 regulator gears. I guess this is what you get when you buy something at a mechanics auction.
  4. Sep 9, 2016 at 7:00 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena, Montana
    Jeep
    I think that is what you get when you buy something which has been on the road for 44 years. lol
    At least you were able to figure it out. It looks like you should be able to get a proper regulator from whatI see. IF that is all that is needed to change...IDK.
    Good luck with it.
  5. Sep 28, 2017 at 9:48 AM
    jeepnut45
    jeepnut45 Member
    Paul M
    '83 Wagoneer
    1959 Willys Wagon, 300 ci Buick engine 4wd
    I replaced my motor switch with one from BJ Off Road. About $85.00, high but worth it. No one else has anything similar.
  6. Sep 28, 2017 at 9:51 AM
    jeepnut45
    jeepnut45 Member
    Paul M
    '83 Wagoneer
    I took my motor apart, cleaned out all the old grease, regreased it, put it back together. Works great. Only problem with these are the plastic gear. If you can find an old motor then swap out the plastic gear.
