1974 Jeep CJ5 Engine Question
Discussion in 'General Jeep Discussion' started by jschneider999, Sep 2, 2020.
  1. Sep 2, 2020 at 11:01 AM
    jschneider999
    jschneider999 [OP] Member
    John
    1974 Jeep CJ5
    I have a 1974 Jeep CJ5 with a V8 engine, this is the original engine that came with the vehicle.
    I want to swap it out with a V6 engine for off-roading.
    I would like to do as little work as possible, IE. Pull engine replace with new engine.
    Is this possible if I find a 1974 Jeep CJ5 V6 or is there more to it than that?
    Any/all advice is appreciated, thanks in advance.
  2. Sep 2, 2020 at 11:54 AM
    Welcome from North Central West Virginia
    I don’t think they had V6 back in 1974 in a CJ5
  3. Sep 2, 2020 at 12:01 PM
    The CJ5 used the Buick 225 V6 from '66 thru '71. A great engine with the H.E.I. ignition, with lots of torque. Although a slight down grade from a V8. I am sure it would be a direct bolt in. Just extend the fan length.
  4. Sep 2, 2020 at 12:13 PM
    I did not know that I didn’t think V sixes came around until in the 80s. My bad
  5. Sep 3, 2020 at 8:23 AM
    jschneider999
    John
    1974 Jeep CJ5
    Thanks Jim, is there an easy way to extend the fan length?
  6. Sep 3, 2020 at 9:28 AM
    Extending the fan shroud might be needed too.
  7. Sep 3, 2020 at 12:50 PM
    A local auto parts should have a cooling fan extension spacer. I installed one on my CJ to convert from the clutching style fan to a fixed fan for crawling in the desert. Although you might be able to move your radiator closer to the engine as your CJ is designed to accept a four cylinder engine. The fan should be about an inch away from the radiator to account for fan flexing.
  8. Sep 10, 2020 at 11:01 AM
    jschneider999
    John
    1974 Jeep CJ5
    Does anyone have a recommended manual to purchase like Chiltons/Haynes/etc.
  9. Sep 13, 2020 at 12:34 AM
    jeepnik
    jeepnik Member
    1982 CJ-8
    Both and scout around for a manufacture's shop manual.
    While you're at it try to find an older Jeep Bible. Beyond the practical knowledge the adventures of Super Pup and quite entertaining.
  10. Oct 15, 2020 at 9:53 AM
    jschneider999
    John
    1974 Jeep CJ5
    I have another question. This jeep has a 3 speed manual transmission. To remove the engine I'm not sure how to disconnect the transmission from the engine. I see what looks like an inspection plate (see picture) between the oil pan and the manual transmission box. Will I be able to disconnect the transmission once I remove the inspection plate? Any info on how to remove the clutch connection would be helpful as well.
