1979 CJ5 axle bearings
Discussion in 'CJ' started by Jcrotts110, May 29, 2022.
  1. May 29, 2022 at 6:14 PM
    Jcrotts110
    Jcrotts110 [OP] New Member
    Hello all. Heck of a first post here. I am trying to repair the cluster f*** of a job someone did on the rear axle of a CJ5, and thought I would ask those more knowledgeable than me.
    It's an AMC 20 with 1 piece axles. I had the new wheel bearing pressed on. Outer seal, backing plate, race, bearing, reused old retainer. With everything tightened down to the housing the wheel bearing feels VERY tight. Is this normal? Will it "wear in"?
    I have no reference as the old bearing exploded in the housing and the opposite side has the wrong bearing and no inner seal. I saw something about shims but the axles didn't have them before, and the ones I saw were for the Dana axle.
    Any help would be appreciated as I'm going behind someone else's "90 percent done" restoration. I'm sure you all know how that goes.
