1991 YJ Washer Fluid Tank Filter
Discussion in 'Wrangler YJ (1986-1995)' started by 91-Jeep-YJ, Nov 30, 2019.
  1. Nov 30, 2019 at 7:15 PM
    91-Jeep-YJ
    91-Jeep-YJ [OP] Member
    Mike
    1991 Jeep Wrangler YJ
    4 inch lift
    The washer fluid filter in the tank is broken and I can't find one anywhere. Anyone know where to get one?
  2. Nov 30, 2019 at 7:47 PM
  3. Nov 30, 2019 at 8:10 PM
    91-Jeep-YJ
    Mike
    4 inch lift
  4. Nov 30, 2019 at 8:36 PM
    Like I said. Best I could come up with. Quadratec is a good place to start. Best of luck with your search.
  5. Dec 1, 2019 at 7:29 AM
    91-Jeep-YJ
    Mike
    4 inch lift
    Thanks for checking bro.
    JKBob 25[QUOTED] likes this.
  6. Dec 1, 2019 at 9:38 AM
    :thumbsup:
  7. Dec 1, 2019 at 10:36 AM
    Just curious...are you referring to that little yellow washer fluid filter some vehicles have? Is it even necessary? Since it filters only debris in otherwise clean washer fluid I'm sure any small filter would suffice or none at all.
  8. Dec 1, 2019 at 4:13 PM
    91-Jeep-YJ
    Mike
    4 inch lift
    Yes.....The original plastic nut inside the washer fluid tank that holds the pump in place had a filter on it. You're correct in saying it just filters debris from the tank but if you do happen to get something in the tank, and it gets into the line, then it will easily clog the spray nozzle if it gets that far. I'm thinking that I can just get a small inline filter to do the same thing.
  9. Dec 2, 2019 at 5:39 AM
    91-Jeep-YJ
    Mike
    4 inch lift
    This is actually the part I'm looking for. I believe this was the filter installed from the factory.
  10. Dec 2, 2019 at 6:05 AM
    That looks more like a screen than the yellow filter I've seen but it would block small debris from entering the lines. Perhaps repurpose a small section of stainless screening.
  11. Dec 2, 2019 at 10:10 AM
    This. Maybe check a Pet Supply store for some screen for a fish tank? Or better yet, a local hardware store that sells Stainless Steel mesh?
  12. Dec 2, 2019 at 3:20 PM
    91-Jeep-YJ
    Mike
    4 inch lift
    Yeah it is more of a screen than a filter. I'm thinking of cutting the screen down some snd gluing it on the nut.
  13. Dec 2, 2019 at 7:05 PM
    I have a roll of stainless steel screen that I use to replace window screens. If you need a slice. LMK....No cost.
  14. Dec 2, 2019 at 7:16 PM
    I don't recommend using glue. Zip tie or SS wire wrap
  15. Dec 3, 2019 at 5:05 AM
    91-Jeep-YJ
    Mike
    4 inch lift
    That's a good idea. Thanks for the offer but I should be able to find something. : )
