1995 Jeep Cherokee Laredo Stalling Help
Discussion in 'Cherokee' started by Slowtrain129, Sep 18, 2017.
  1. Sep 18, 2017 at 6:33 AM
    Slowtrain129
    Slowtrain129 [OP] New Member
    1995 Jeep Grand Cherokee
    None
    Needing some help or advice now. The Jeep keeps stalling at extended idles or when letting off the gas while turning or braking. This is a random issue and does not happen all the time. I have replaced the coil in the distributor, new battery, alternator, cleaned the TPS solenoid, replaced the CPS (crank position sensor), installed new battery leads and terminals.
    The thing stalled not 10 minutes after installing the new CPS. Once it stalls, it will turn over and normal but won't fire/start up. I let is sit for 15-30 minutes and it will fire up and run for days or stall on the next drive......any thoughts?
  2. Sep 18, 2017 at 7:11 PM
    Welcome to the site.
    Hang tight. We have a bunch of very knowledgeable members. If some feels they can help.....they will.
  3. Sep 19, 2017 at 9:18 AM
    Slowtrain129
    None
    Thanks, JKBob. I worked on it last night and changed the ignition coil out, reinstalled the stock air filter box along with all the vacuum hoses and it still stalled out. I read something about removing and cutting a screw that mounts the computer to the firewall. I didn't do that, but seems to just make a better ground for the computer.....
  4. Sep 19, 2017 at 12:22 PM
    Check your engine ground straps and make sure they are tight and clean.
  5. Sep 19, 2017 at 8:36 PM
    Jeepmechanic2003
    Jeepmechanic2003 Member
    David
    Grand cherokee
    Stock for now
    Sounds like the heated o2 sensor problem had a customers yj do this only would happen after 30 to 40 minutes of driving come to find out the heat o2 sensor had an internal short when it got hot shut the engine off for a good 15 to 20 minutes
  6. Sep 20, 2017 at 7:18 PM
    Kinda off topic.
    Just want to welcome jeepmechanic2003 to the forum. He didn't introduce himself to us. But that's cool. Some members can be a little shy. :pout:. But they have posted in threads and helped and shared their knowledge which helped another member. :wave:. Thank you.
    Welcome jeepmechanic2003. Awesome to have you as member. :). We are......JEEPS DOT NET.....
  7. Sep 20, 2017 at 10:23 PM
    Jeepmechanic2003
    David
    Grand cherokee
    Stock for now
    Hello i am david aka jeepmechanic2003 was a jeep mechanic from 1999-2003 but now a diesel mechanic.
