1995 jeep wrangler check engine light
Discussion in 'CJ' started by hoops8765, Feb 7, 2018.
  1. Feb 7, 2018 at 8:06 AM
    hoops8765
    hoops8765 [OP] New Member
    nick
    1995 jeep wrangler
    my 1995 jeep wrangler 4 cyl auto. will not start untill the check engine light is on,.
    you turn the key on and wait 30sec. to a min. if the check engine light is on, it
    will start right up. can anyone tell me what causes this..
  2. Feb 7, 2018 at 8:51 AM
    Welcome to Jeeps.net! Have you read the code yet? The code and any code history will help us help you. Some auto parts store may offer code readers for rent, purchase or perform the service.
  3. Feb 7, 2018 at 10:24 AM
    Welcome aboard! I agree with aggrex. Get the code read and let us know what it is.
  4. Feb 7, 2018 at 12:02 PM
    @aggrex The 95 is pre-OBDII code software. Is there a code reader for it?
  5. Feb 7, 2018 at 2:18 PM
    I'll check as that's before my time....LoL
  6. Feb 7, 2018 at 4:28 PM
    I found this:
    OFFGRID likes this.
  7. Feb 7, 2018 at 4:30 PM
    From what I have found, OBD 1 is for years 1991 thru 1996....?
    aggrex and OFFGRID like this.
  8. Feb 8, 2018 at 9:37 AM
    Because I like to play with YJs I have purchased service manuals for them. Couldn't play without them. Some of the more modern 80s cars and trucks had OBD1 as well I believe. From what i have read, the problem with OBD1 is that each manufacturer had its own coding so you had to have a code reader for each. OBD2 was mandated by the feds to make a universal code that was accessible by all more easily. For OBD1 you are supposed to be able to count flashes for code numbers, but I don't know the essentials of the trick. I will research this some more, but as of yet I really have not needed it.
    aggrex, JKBob 25 and chris4x4[QUOTED] like this.
  9. Feb 8, 2018 at 7:51 PM
    Welcome to the forum hoops8865.
    Well, your off to a flying start dude. You presented an issue we have not seen. And since I am in no way as knowledgeable when it comes to code reading and issues with older Jeeps as other members do. So Im gonna sit back and read this one and try to pick up tips that other members post. Can never be over educated. Is that such a thing. Lolll.
    Welcome to the forum Nick.
  10. Feb 9, 2018 at 7:59 AM
    Here is a perfect video on reading OBD1 codes.
    https://youtu.be/KTZAJSHtBkk
    I read somewhere else that to get to the code reading mode in pre-96 Cherokees you have to turn the key 5 times.
  11. Feb 9, 2018 at 9:58 AM
    Is my quote in post #6 accurate?
    aggrex and OFFGRID[QUOTED] like this.
  12. Feb 9, 2018 at 7:42 PM
    Holy crap @OFFGRID. Where the hell did you find that. Sweet info. Ill never need it. But you.....wow. Jeeps Dot Net...MVP.
    OFFGRID[QUOTED] and chris4x4 like this.
