1999 grand cherokee wont start
Discussion in 'New Member Introductions' started by Jeeper83, Jun 17, 2017.
  1. Jun 17, 2017 at 9:18 AM
    Jeeper83
    Jeeper83 [OP] New Member
    Jason
    1999 jepp grand cherokee
    None
    I turn the key and all lights work but wont start. Was thinking a starter or the ignition switch or tumbler. Is there anything else that it could be.
  2. Jun 17, 2017 at 7:48 PM
    Welcome! Any crank, click, spin, whirring, light dimming or dead silence? Community just needs more clues.
  3. Jun 17, 2017 at 8:06 PM
    Jeeper83
    Jason
    None
    Dead silence except when the starter/ignition fuse blows. I changed the starter/ignition fuse. Changed the ignition switch. After changing the ignition switch it continuously blows the starter/ignition fuse every time i turn it over. The dash lights work. Headlights work but also the windows will not roll up either. Im at a loss. I was think a direct short but i have no clue if im right or where it would be or where to start.
  4. Jun 17, 2017 at 8:38 PM
    Could it be a loose or corroded ground from the battery to the block?
  5. Jun 17, 2017 at 8:39 PM
    Jeeper83
    Jason
    None
    Not sure but i will check that
