2000 cherokee auto - manual trans swap
Discussion in 'General Jeep Discussion' started by FieldServiceTech69, Sep 6, 2019.
Is swapping this manual trans into this originally auto trans XJ possible
  1. YES
    2 vote(s)
    100.0%
  2. NO
    0 vote(s)
    0.0%
  1. Sep 6, 2019 at 2:21 PM
    FieldServiceTech69
    FieldServiceTech69 [OP] New Member
    Anthony
    New Jersey
    2000 Cherokee Sport
    In the process of teardown.. mods to be determined.
    Hello there,
    I have a 2000 cherokee sport. It came from the factory with an automatic trans and Distributorless electronic ignition. Its not my daily anymore and id like to put a manual transmission in it. ( Motor and trans are out of the vehicle currently )
    I have a manual trans P/N 52108047AB i got from a salvage yard which fits XJ's from 97-99. Im not sure though, if this will work with my 4.0 liter from 2000. Can i just install a flywheel on the back of this 4.0 liter, clutch assembly, etc and have the same setup mechanically as a 99 using this transmission?
    I have to get an ECU for a M / T and harness as well. P/N 56041667AD was the ECU i had in mind. I can get one programmed to work with my motor by referencing the VIN.. will work with manual trans and control electronic ignition for year 2000.. allegedly.
    Also can i use the 4x4 transfer case from the auto trans?
    If anyone has done something like this before and can confirm something like this will work / give any tips, I'd appreciate the feedback.
    Below are links to the trans i have and the ECU i was considering.
    Thanks,
    Anthony
    https://www.moparpartsgiant.com/parts/mopar-trans-5-speed~52108047ab.html
    https://www.ebay.com/itm/Engine-Com...m=352263346477&_trksid=p2047675.c100011.m1850
