2003 jeep grand Cherokee loredo 4.0
Discussion in 'Grand Cherokee' started by Realtree1986, Sep 11, 2017.
  1. Sep 11, 2017 at 5:20 PM
    Realtree1986
    Realtree1986 [OP] New Member
    Travis
    Okay people I'm stumped on this one! So here it goes the other day I got a bump in the road. In result of that my blinkers and a.c. and heat all went out ? So here is what I did to acess the problem I replaced blinker relay fuse a.c. blower motor and climate relay sensor and still nothing no other fuse is blown that I can find. So I'm stumped does any have an answer that can help me figure this out?
  2. Sep 11, 2017 at 6:20 PM
    Challenging problem to diagnose online that could be related to a loose or bad ground or short in the wiring harness aggravating the electronics by impacts from the road.
  3. Sep 14, 2017 at 4:02 PM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    a haynes manual always helps me with electrical trouble. you gotta look at the wiring info.
  4. Sep 14, 2017 at 6:58 PM
    Welcome to the forum.
    Agreed. Sounds like a wiring issue.
    The only experience I have with an issue similar to this. An Ex hit a bump so hard. It broke a battery terminal. And her JKU started acting like it was possessed. Turn signals worked on and off, ac the same. Would just shut down, and start right up. A big box auto repair couldn't find it. I started at ground zero. The battery. Bingo...If not the issue. Relays and fuses are a good place to start.
