2003 Sahara with some issues
Discussion in 'Wrangler TJ (1996-2006)' started by Rah86, Jun 16, 2017.
  1. Jun 16, 2017 at 11:50 AM
    Rah86
    Rah86 [OP] New Member
    2003 wrangler sahara
    Hi all! Looking for some advice/moral support here. My 03 Sahara is not in the greatest of shape but I'm not ready to let it go. Body's in very decent shape, minimal/usual jeep rust. The problems I'm having are possible u joint and ball joints needing to be replaced in the front (waiting on a mechanic who is a close friend to get it up on his lift to see what's really going on) and a slow leak in the trans. I've got 168,000 miles on it. What's everyone's opinions
    .. is it worth putting possibly $2000 + into fixing these issues or should I call it a day? Y'all know how attached one can get to their jeep! I will update once I have a full diagnosis as well. Thanks!
  2. Jun 16, 2017 at 1:02 PM
    Welcome! Ball joints and a leak are all easy repaired, and no reason to consider cutting a vehicle loose. Ball joints shouldn't be an expensive issue, and can be done yourself, or with assistance from a friend. The leak shouldn't be very much either, depending on where the leak is. Keep us posted.
  3. Jun 16, 2017 at 1:02 PM
    Oh....and post pictures. We love to see jeep pics :)
  4. Jun 16, 2017 at 1:06 PM
    Rah86
    Thanks Chris. I think my mechanics concern is that there could be more issues with the suspension and the trans and that they will compound. I'm with you, I think I'm good to go for a while if the mentioned issues get resolved.
  5. Jun 16, 2017 at 3:01 PM
    Based on your description "body's in very decent shape, minimal/usual jeep rust" that sounds like an excellent base vehicle to repair/improve upon. And based on your committment "i'm not ready to let it go" sounds like jeep luv. Anyway as stated already the ball joints / slow leak are usually considered maintenance issues that are relatively easy, not expensive and necessary repairs.
  6. Jun 16, 2017 at 7:09 PM
    My $0.02. If you are going to sell it, you probably won't get your make the money back if you are paying someone else to do the work. You can spend over a grand on a complete front end rebuild of the suspension. I'd sell it as is unless you can do the work yourself. If your going to keep it, by all means do the work. It will make it feel like a new jeep again.
