2004 LJ lighting issue
Discussion in 'Wrangler TJ (1996-2006)' started by OFFGRID, Dec 9, 2017.
  1. Dec 9, 2017 at 6:12 PM
    OFFGRID [OP] Well-Known Member
    Alright guys I need a little help. I was helping a friend install LED marker lights in front of his jeep and we blew a fuse I think. The Parking lights won't come on yet they will blink when turn signal is on. He also stated that on his drive home the dash lights were out. The headlights do work. I found the fuse box under the hood. They are not well marked. I did see a 20amp fuse blown labled exterior lights. I replaced it. Still no parking lights. Dose anybody know where the parking lights/dashlights fuse is. I thought I checked them all and they looked good. Thanks for your help. He does not have an owners manual. . .
  2. Dec 9, 2017 at 6:38 PM
    Does this help?
    OFFGRID [OP] and JKBob 25 like this.
  3. Dec 10, 2017 at 6:37 PM
    thanks. i found a second fuse block behind the glovebox. the bad fuse was there.
  4. Dec 10, 2017 at 7:40 PM
    Good to hear! I keep forgetting about the inside ones. :anonymous:
  5. Feb 11, 2018 at 6:18 AM
    Lineman 27kv
    Lineman 27kv New Member
    John
    2001 black wrangler
    I have an issue with 2001 tj dashboard and taillight out. Found blown fuse inside glove compartment replaced it and it blew . Trying to figured out where to start looking for the dead short. Any idea is welcome
  6. Feb 11, 2018 at 7:52 AM
    I would check to see what else might be on that circuit, and check to see of there is a broken wire, or bad connection.
  7. Feb 12, 2018 at 5:25 AM
    Lineman 27kv
    John
    2001 black wrangler
