2005 TJ stalls after reaching operating temp.
Discussion in 'Wrangler TJ (1996-2006)' started by kenfrog, Dec 22, 2022.
  1. Dec 22, 2022 at 11:07 AM
    kenfrog
    kenfrog [OP] New Member
    kenny
    2005 jeep tj
    4 inch lift, 35's,
    After it cools will restart and run and then quit. Replaced, 4 o2's, ck and cam sensor, map. Help
  2. Jan 16, 2023 at 9:52 PM
    SmittyJeeper
    06 wrangler 4.0 6speed
    Would need more info on when it started and does it over heat? First impression is your ecm is getting hot acting up/going out. Codes? Spark when it happens?
