2011 Liberty Tire Pressure reset
Discussion in 'General Jeep Discussion' started by TJ4me, Nov 29, 2019.
  1. Nov 29, 2019 at 9:10 AM
    TJ4me
    TJ4me [OP] Active Member
    2001 Jeep Wrangler Sahara
    The tire pressure light blinks on start up and then stays on steady in my 2011 Liberty.
    I had two sensors replaced at a tire store. But they could not / did not know how to reset the light. I've read that there is a "set" button under the steering column. But, I can't find it.
    Any ideas or suggestions. Thanks!
  2. Nov 29, 2019 at 9:53 AM
    Have you tried the following?
    1. Insert the key into the ignition.
    2. Turn the key to the "ON" position.
    3. Press and hold the "SET" button. The button is directly below the steering column.
    4. Release the "SET" button when the tire indicator light turns off. Turn the ignition to the "OFF" position.
  3. Dec 1, 2019 at 1:47 PM
    TJ4me
    Thank you for the response.
    I'm having a hard time finding the elusive "set" button...
  4. Dec 1, 2019 at 2:43 PM
    Unusual for tire store that can install the sensor not to know how to reset / relearn the TPMS system. Installed the correct tpms sensor and undamaged? Tire pressure correct as per tire pressure label on the door?
  5. Dec 1, 2019 at 3:17 PM
    TJ4me
    Thanks for the reply...
    Tire pressure is to spec.
    The tire guys told me to go to the dealer...
    They didn't even charge me for the new sensors...
    It's got to be easier than that....
  6. Dec 2, 2019 at 10:08 AM
    Is there a spot for the set button? Im thinking it may have been pushed out of place, or out of sight?
