2014 jku soft top. Light bar noise is crazy
Discussion in 'Lighting' started by Jamesbrandy, Jan 7, 2018.
  1. Jan 7, 2018 at 8:26 AM
    Jamesbrandy
    Jamesbrandy [OP] New Member
    2014 jku
    I just put a 52 inch light across the top of my jeep and the noise is crazy. I read you can tilt the light to help but that didn't work. I put the door trim on the fins and that worked a little but it's still loud. Is there a better fix? This is crazy, I'm at the point of taking it off........
  2. Jan 7, 2018 at 8:31 AM
    welcome to the site! Precisely one of the reasons I run my lights near the mirrors.
  3. Jan 7, 2018 at 3:31 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Welcome to the forum. Good looking jeep.
  4. Jan 7, 2018 at 4:06 PM
    Welcome! The 52" light bar looks awesome until speeds are reached when the whistling begins. Most of the DIY fixes revolve around interfering with the wind whipping past the light bar cooling fins. Perhaps try a different style door insulation from HD or Lowes or the $$ version sold on Amazon since you are committed to that spendy light bar.
    OFFGRID, JKBob 25 and chris4x4 like this.
  5. Jan 7, 2018 at 5:01 PM
    I actually was wondering if they had a rounded lens for them. Seems that would make sense if the OEM's made them like that.
  6. Jan 7, 2018 at 6:45 PM
    Welcome to the forum @Jamesbrandy. Nice rig dude.
    I've been contemplating a 52 inch bar. And the issues with the noise I've heard they make. Keeps me from installing one. But, @aggrex, sweet idea. Does any one use that Light Bar Silencer? Looks like a great idea.
  7. Apr 9, 2018 at 1:55 PM
    Oglesbyjeep
    Oglesbyjeep New Member
    2014 wrangler
    52” light bar
    I installed at 52” light bar and after reaching 45 miles an hour and up I have vibration in the front tires. Any thoughts??
  8. Apr 9, 2018 at 1:57 PM
    boondoc89 Well-Known Member
    :eek: lol
  9. Apr 9, 2018 at 2:43 PM
    Most jeepers complain of noise from the light bar but vibrating the front wheels is a first. Perhaps you're experiencing the 4 forces of flight: lift, thrust, drag and weight
  10. Apr 9, 2018 at 4:14 PM
    Oglesbyjeep
    2014 wrangler
    52” light bar
    I have to first check if my tires are out of balance. I also had a total detail (it looks great) and my body guy says it possible some of the wheel weights were removed during that process4FBFD2CE-0AE2-46D5-9B1F-C1954C0CA4A1.jpg
    OFFGRID likes this.
  11. Apr 9, 2018 at 4:19 PM
    That's a badass ride man. The balancing weights would be my first place to check and then get deeper into inspection if that's not the case.
    JKBob 25 and Oglesbyjeep[QUOTED] like this.
  12. Apr 9, 2018 at 4:45 PM
    Oglesbyjeep
    2014 wrangler
    52” light bar
    Thanks. I’ll post what happens after the balance.
  13. Apr 12, 2018 at 5:31 PM
    Oglesbyjeep
    2014 wrangler
    52” light bar
    I had my tires rotated and balanced. Still getting vibration at 40 mph plus. Any thoughts. Is it just the wind??
  14. Apr 12, 2018 at 7:18 PM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    Warn bushings in your steering maybe?
  15. Apr 12, 2018 at 7:27 PM
    Wow. Doubt its just the wind honestly. Where excatly do you feel vibrations? Steerin wheel its self? In the rear? Time to start lookin at suspension parts. Look at tie rod, sway bar, and drag link bushings. Jack it up and check ball joints. Without goin into alot a cash. That's where I'd start. Bushings.
  16. Apr 13, 2018 at 8:53 AM
    Where are you feeling this vibration. Is it in the steering wheel? Does the steering wheel shake left and right in your hands? Or are you feeling it in your feet, or the seat of your pants? Once you get up to 33s and bigger, sometimes I have had to have tires balanced multiple times before they get it right. Discount tire has the best balancers out there. I know I have been looking for some for the shop I want to open this summer. Their balancer is like $20k. Doesn't matter how expensive the balancer is if the technician just doesn't care or is not a very good technician.
    How many miles are on your jeep? Have you lifted it? If your tires are truly balanced the next place I would look would be your drive shafts. JK driveshafts are known to where out fast once you lift it. Tom Woods has excellent drive shaft kits that update your jeep to fixed yokes at the Tcase with CV style drive shafts.
