2014 wrangler electric live power windows
Discussion in 'Wrangler JK (2007-2017)' started by solrac, Nov 20, 2016.
  1. Nov 20, 2016 at 4:54 PM
    solrac
    solrac [OP] New Member
    can some one tell me where I should connect for power source
  2. Nov 21, 2016 at 6:37 AM
    What kit is it?
  3. Nov 21, 2016 at 7:18 AM
    solrac
    is the je-17
  4. Nov 21, 2016 at 7:28 AM
    solrac
  5. Nov 21, 2016 at 5:42 PM
    pink/white wire from the ignition is where to tie in for the switched 12v power
  6. Nov 21, 2016 at 6:49 PM
    It sure would be cool to be able to let the steam out without having to turn the key and the lights come on etc. Hahaha.
