2018 Grand Cherokee headlights dry from inside
Discussion in 'Grand Cherokee' started by alexandro.619, Aug 23, 2020.
  1. Aug 23, 2020 at 6:25 AM
    alexandro.619
    alexandro.619 [OP] New Member
    2018 grand cherokee altitude
    non
    Hi,
    Is there any one else having this issue with their headlights?
    It does not seem like condensation, it looks like if the inner headlight was dry and peeling some flakes on one side. I blew some air thinking it was condensation and nothing happen than I inserted a screw driver with cloth and seems like its just dryness..
  2. Aug 23, 2020 at 7:16 AM
    Is it just on one side? Does it go away after the head lights heat up from use? Sometimes limited condensation happens but excess condensation may indicate a failed seal or crack. Replacement may be in order unless you want to try sealing it.
  3. Aug 23, 2020 at 2:37 PM
    I have had condensation on my '07 GC. I removed it and drilled a drain hole in the bottom, I have done this on other vehicles also.
  4. Aug 23, 2020 at 4:41 PM
    I took mine back to the dealer and they replace it with a new one :)
    is was still under warranty :bananadance:
  5. Aug 24, 2020 at 12:16 AM
    alexandro.619
    non
    The other side is barely starting to happen. Its there all the time, doesnt change if I use the headlight or not. It doesn't seem like condensation, that is what I dont understand.
  6. Aug 24, 2020 at 12:17 AM
    alexandro.619
    non
    I will go to the dealer see if they will replace it. It has 32k miles so i might be on my own
    LYFZGOOD[QUOTED] likes this.
  7. Nov 18, 2020 at 7:07 PM
    andrew8c
    andrew8c Member
    I've had almost the same thing with my old headlights, and the only that helped - purchase of new ones. Here is a great resource with LED headlights for Jeeps. And they have pretty nice and relevant information about those models, I gotta say. I didn't even realize how different they are.
