4.0 misfire
Discussion in 'Wrangler TJ (1996-2006)' started by 1Newbie, May 7, 2022.
  1. May 7, 2022 at 1:47 PM
    1Newbie
    1Newbie [OP] New Member
    2005 wrangler x 4.0
    31” tires
    I have a 05 wrangler 4.0. Newest issue is a misfire code. P0305 p2096 p2098. I changed coil. Nothing. Changed #5 injector. Nothing. Still missing like a dead cylinder. Prior to this I’ve been battling lean codes on all o2. I have changed them all.
  2. May 22, 2022 at 11:54 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    I'd check cylinder compression to see if #5 is low and do a vacuum leak down test. Sounds like you've already changed all the likely suspects.
