6 speed manual problems
Discussion in 'Liberty' started by lenasue44, Oct 28, 2022.
  1. Oct 28, 2022 at 7:00 AM
    lenasue44
    lenasue44 [OP] New Member
    lena
    2008 jeep liberty sport 6 speed maual
    I have a 08 Liberty Sport with new clutch kit , dual mass flywheel and slave cylinder . The problem is it goes through the gears easy while its not running but running it dont want too go in any gear (has good clutch pedal) Please help
  2. Oct 31, 2022 at 12:33 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    Assuming the transmission shifted normally before, your new clutch/flywheel/slave cylinder arrangement isn't fully disengaging. It could be all three but I would most suspect the slave cylinder. If it is the same diameter as the old one, it probably still has some air in the system.
