88 yj 4.2/5 speed
Discussion in 'Wrangler YJ (1986-1995)' started by dgmiller1, Nov 27, 2019.
  1. Nov 27, 2019 at 3:07 PM
    dgmiller1
    dgmiller1 [OP] New Member
    Doug
    1988 wrangler sahara 6 cyl/5 speed
    I’ve got an 88 sahara yj 6 cyl 5 speed with continuing starting issues. Cranks and cranks but wont start with out spraying start fluid directly into the carb. Then starts right up and runs good.
    Replaced filter and fuel pump and then the carb. Still same problem. Seems like fuel is draining back away from carb. Any thoughts appreciated.
