93 ZJ 46RH Filter An Pan Replacement
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Nov 2, 2019.
  1. Nov 2, 2019 at 4:51 PM
    TinyInkognegroT
    How many bolts hold the filter and what size star head are they ?
    boondoc89 likes this.
  2. Nov 3, 2019 at 10:08 AM
    TinyInkognegroT
    There's three and they are T25 torx
  3. Nov 4, 2019 at 9:46 AM
    boondoc89 Well-Known Member
    I see what you did there lol
  4. Nov 5, 2019 at 11:13 AM
    TinyInkognegroT
    There were some shavings in the bottom of the pan. The magnet was covered in black silverish guck. Here's a pic of the transmission filter. Overall what do you guys think?
  5. Nov 5, 2019 at 11:17 AM
    TinyInkognegroT
    Here is the new pan with the drain plug and a new rubber gasket.PHOTO_20191105_125043.jpg PHOTO_20191105_130423.jpg
    I have hi temp RTV silicone. Do I need to add a layer of it under or on the new gasket? Or do I even need it at all?PHOTO_20191105_130529.jpg
  6. Nov 5, 2019 at 12:36 PM
    TinyInkognegroT
    Pan installed... I didn't use the RTV silicone, just the gasket itself PHOTO_20191105_141737.jpg
  7. Nov 5, 2019 at 12:39 PM
    TinyInkognegroT
    About to add 5 quarts of ATF +4 fluid and a quart of Lucas transmission fix or another quart of ATF+4, depending on how it shifts after. Totaling 6 quarts for pan drain.
  8. Nov 5, 2019 at 2:49 PM
    Generally some metal shaving or black-silver muck on the magnet is ok due to wear and mileage of the vehicle. Follow the specified bolt tightening pattern and don't over tighten the bolts. Refer to manual for refill capacity for a drain. Check hot trans fluid level on level surface.
  9. Nov 5, 2019 at 3:37 PM
    TinyInkognegroT
    So when I'm working with these exhaust adapters, am I supposed to get a quarter inch bigger than the exhaust pipe to slide over the original exhaust pipe or a quarter inch smaller to slide in the exhaust pipe?
  10. Nov 5, 2019 at 3:45 PM
    TinyInkognegroT
  11. Nov 5, 2019 at 3:46 PM
    Hey this is the transmission section...lol
    The adapters are available in different combinations of I.D. and O.D. Generally choose whatever adapter works best for your application. It will never be as smooth as one-piece pipe but you got to do with what you have.
  12. Nov 5, 2019 at 3:53 PM
    TinyInkognegroT
    Yea I forgot lol...
