93 ZJ 5.2L Fuel Rail/Fuel Pressure Sending Unit Leak
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Oct 17, 2019.
  1. Oct 17, 2019 at 8:37 AM
    TinyInkognegroT
    Started smelling gas with the engine running but there's no gas leak coming from the gas tank or fuel pump. I opened up the hood to find on the driver side fuel rail where the Schrader valve is and towards the back by the distributor, there's a piece attached to the fuel line rail that is leaking gas... Here is a video I took yesterday
    https://youtu.be/4FWvSDeZ9mQ
  2. Oct 17, 2019 at 8:51 AM
    looks like FPR -fuel pressure regulator. Remove the vac line should be NO fuel in line BUT I suspect as you did not work with it lately? a new component FPR is needed.
    1 bolt a new o ring (comes installed)
  3. Oct 17, 2019 at 9:05 AM
    TinyInkognegroT
    Thank you! @Awrench
  4. Oct 17, 2019 at 9:10 AM
    TinyInkognegroT
    Do I have to replace the whole regulator or can I replace the o-ring? Or pull it regulator from the salvage yard? A new regulator is like $80 and I'm afraid I'm not going to have that until next Friday
  5. Oct 17, 2019 at 9:12 AM
    Bingo.
    Relatively expensive for it's size at about $80.
  6. Oct 17, 2019 at 9:19 AM
    You could try replacing the O-rings, they are cheap and the job isn't that hard so if it didn't work you aren't out much money or time.
    A junkyard part may get you by but if it's an original part as well then you are on borrowed time....but maybe that is all you need.
  7. Oct 17, 2019 at 9:22 AM
    tHIS IS A FUEL LEAK - priority- NOT i WILL GET TO IT AND CONTINURE TO RUN ENGINE -
    yOU will have to get it apart, a good eye on the exact location of leak - I mentioned the VACUUM LIne as that is evidence of a diaphragm failure of FPR, Yes the "O" ring may have failed I cant guess its a lets inspect, check type of situation.
    SORRRY STICKIng KEYS
  8. Oct 17, 2019 at 10:51 AM
    TinyInkognegroT
    I'm going to get to it after work today, but I do have to drive it tomorrow to work and back and then I'm off for the weekend so I won't be driving and I'll be fixing that regulator
  9. Oct 17, 2019 at 10:53 AM
    TinyInkognegroT
    So I need to check that vacuum line too ? Is the vacuum line attached to it so I can find it or can you send me a diagram or picture of the location of it?
  10. Oct 17, 2019 at 1:41 PM
    TinyInkognegroT
    Does anybody know the size of the o-ring? I'm trying to buy one but nobody seems to have this specific o-ring for the fuel pressure regulator. I'll have to take off the fuel pressure regulator and walk to the auto parts store to size it
  11. Oct 17, 2019 at 3:29 PM
    Auto parts store might have a few FPR to check out to compare O-rings
  12. Oct 18, 2019 at 9:27 AM
    TinyInkognegroT
    Took my fuel pressure regulator off and took it to AutoZone and they had a o-ring assortment kit for 8 bucks. Nothing seemed to match the little o ring but there was a match for the bigger one and I used it and now I have no leak... FYI, if you're using o-rings for fuel related repairs, the brown assortment kit is for fuel-related repairs, not the black ones.
    aggrex[QUOTED] likes this.
  13. Oct 18, 2019 at 9:41 AM
    8$ bucks all done GREAT!!! :thumbsup:
    What is next project?
  14. Oct 18, 2019 at 9:43 AM
    TinyInkognegroT
