93 ZJ fuel pressure at 30 PSI
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Sep 8, 2019.
  1. Sep 8, 2019 at 10:42 AM
    TinyInkognegroT
    I just did a fuel pressure test on my 93 ZJ and it read 30 PSI. I removed the fuel filter and the gas was a little dirty but I can blow through it can feel air coming out the other end... Not sure if I should replace the filter or check the fuel pump...
  2. Sep 8, 2019 at 10:59 AM
    TinyInkognegroT
    Okay after research, turns out 30-33 PSIis the fuel pressure needed for a 5.2 L... So there's nothing wrong with my fuel system.
