93 ZJ Rear Axle Leak
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Oct 11, 2019.
  1. Oct 11, 2019 at 4:20 AM
    TinyInkognegroT
    My rear axle is leaking but not too bad but it does have a leak. I was told when I bought the Jeep that I would have to replace the seal. How do I do that?
  2. Oct 11, 2019 at 4:57 AM
    lets start at the beginning..
    details
  3. Oct 11, 2019 at 11:02 AM
    TinyInkognegroT
    My rear axle is Dana 35
  4. Oct 11, 2019 at 11:41 AM
    Pop the cover off with a drain pan underneath as the fluid will dump out. Clean the mounting surfaces good and either go back with a gasket or some RTV.
    LubeLocker gaskets are nice, but RTV is cheap.
    Once it's back together fill it until you can touch fluid by putting your finger into the fill hole the your first knuckle.
    TinyInkognegroT[OP] and JKBob 25 like this.
  5. Oct 11, 2019 at 12:00 PM
    Me thinks he wants to change AXLE shaft seals.
    I will add info later
  6. Oct 12, 2019 at 4:03 AM
    TinyInkognegroT
  7. Oct 12, 2019 at 2:43 PM
    Diff housing leak. See my instructions above.
  8. Oct 13, 2019 at 10:14 AM
    TinyInkognegroT
    I bought a new gasket and gear oil, I bought 85w-140 because it was in my budget.
  9. Jan 14, 2020 at 11:57 AM
    TinyInkognegroT
    Can you still add that info to change the axle shaft seals? And what tools would I need to get to it and remove it to replace it?
  10. Jan 15, 2020 at 6:34 AM
    If you don’t know what ur doing I would take it to a dependable garage you have to pull the axles and take out the differential and the seals goes in from the center on the right and left.
  11. Jan 15, 2020 at 8:40 AM
    Until we can locate our favorite wrencher @Awrench...we're going to have roll up the sleeves and get to it lol
  12. Jan 15, 2020 at 9:16 AM
    TinyInkognegroT
    Yeah I kind of did my research last night and I'm working on getting to places to get the things I need now. I didn't mean to say shaft seals, I meant front pinion. Was told from another guy in a Facebook group that the coiled wire is used with the seal, its supposed to hold the seal to the yoke, he said...sound about correct?
    aggrex[QUOTED] likes this.
  13. Jan 15, 2020 at 9:53 AM
    Sounds reasonable as I've done some investigative research on similar coiled springs in some contraceptives. Sometimes I wonder how it got tangled...never mind :notsure:
  14. Jan 15, 2020 at 10:16 AM
    TinyInkognegroT
    then that would mean the pinion seal is trashed. How would the drive shaft and yoke spin if there wasn't a seal there? Would that cause the drive shaft to be unbalanced or would it cause problems if the car was driven that way? Like vibrations?
  15. Jan 15, 2020 at 10:54 AM
    The pinion seal just ensures the fluid does not leak out of the diff. Bad pinion seal won't stop you from driving however big leaks can cause problems quickly.
  16. Jan 15, 2020 at 11:59 AM
    TinyInkognegroT
    I have the tools and parts to replace the seal now and I'm about to go do the job. What else should I look for as I'm doing that ?
  17. Jan 16, 2020 at 9:50 AM
    TinyInkognegroT
    Jeep got illegally towed last night and I have no means of money to get it out. It's been fun talking with you guys! I really appreciate all the help you guys gave me!
  18. Jan 16, 2020 at 9:52 AM
    Hope things work out!
  19. Jan 16, 2020 at 12:04 PM
    Where do you live??
