93 ZJ Rotor and Bearing Replacement
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Oct 7, 2019.
  1. Oct 7, 2019 at 8:35 AM
    TinyInkognegroT
    I have new rotors and hubs and bearings for my front 2 tires. I plan on replacing them today but I'm posting this so I have everything ready when I get home. My biggest concern is how to remove the brake caliper because I'm not sure if it's a 13 mm bolt or a star socket and I don't have any Star socket sets and don't have money today to buy any so I'm hoping that it's the 13 mm bolts. My other concern is the removal of the bearing and hub, what size bolts are these? Are they hard to remove and is the bearing hard to replace?
  2. Oct 7, 2019 at 8:41 AM
    I think the caliper bolt is a regular hexhead, can't recall the size right off.
    The hub however does have a 12 point head on it, 3 bolts from the back side of the spindle.
    You will have to separate the hub from the axle shaft which takes a large socket and you may be able to tap the end of the axle shaft to get it to separate from the hub.
    I have had hubs seize into the spindle and actually pulled the hubs apart. Had to beat the snot out of them to get them out. Clean up the mating surface of the spindle before putting the new hub in.
  3. Oct 7, 2019 at 9:00 AM
    TinyInkognegroT
    Good to hear there's no star heads LOL the biggest socket I have is a 30 mm... If I have to put off the bearings until Friday, that's fine and I'll just install the new brakes and rotors today... Slowly but surely I'm trying to get her fixed up.
  4. Oct 7, 2019 at 9:04 AM
    The Spindle nut on my 93 XJ is a 36mm... just went and looked it up. Likely the same on your ZJ. And 175 lbs-ft is the torque spec.
  5. Oct 7, 2019 at 9:09 AM
    TinyInkognegroT
    Nice, thanks @Prerunner1982
  6. Oct 7, 2019 at 10:23 AM
    TinyInkognegroT
    As another precaution, how can I check the wear and tear on the CV ends of the wheels on the front axle? How can I tell if they'll need replaced or not?
  7. Oct 7, 2019 at 12:00 PM
    I'm sure if you had replacements on hand that you can feel the difference in looseness especially with age+mileage of the jeep. Generally if the boots are not torn they should be okay but let's hear from others opinion. Old worn boots could start tearing from age or rough handling right after assembling all the front end parts lol
  8. Oct 9, 2019 at 9:25 AM
    TinyInkognegroT
    Here are mine... Driver side then passenger side
  9. Oct 9, 2019 at 10:05 AM
    The driverside is definitely in need of being replaced, passenger side may be ok but I would look around that first rib where all the crud is...it is likely torn in there and if you are already doing the hub it would be a good time to replace them both..... if you can, I've been there before.
  10. Oct 9, 2019 at 10:26 AM
    Clean and inspect boot(s) as the crud may be indicative of boot damage with the lube leaking out.
  11. Oct 9, 2019 at 10:58 AM
    TinyInkognegroT
    The crud in the first rib you guys are talking about is on the passenger side?
  12. Oct 9, 2019 at 10:59 AM
    TinyInkognegroT
    Is that a crack and splits on the driver side?
  13. Oct 9, 2019 at 11:05 AM
    TinyInkognegroT
  14. Oct 9, 2019 at 11:05 AM
    Yes
    Yes sir.
  15. Oct 9, 2019 at 11:46 AM
    TinyInkognegroT
    Is this everything I need to replace the back brakes ?
  16. Oct 9, 2019 at 12:02 PM
    Measure your drums, they could be 9" or 10". But yeah that looks like a pretty complete kit.
  17. Oct 9, 2019 at 12:09 PM
    TinyInkognegroT
    9's are smooth around and the 10's have cooling finsScreenshot_20191009-140659.jpg
  18. Oct 9, 2019 at 12:47 PM
    Why are you replacing the rear drums? Are they out of spec? Just trying to stretch your $$$
  19. Oct 9, 2019 at 12:50 PM
    Sure looks like some crack...
  20. Oct 13, 2019 at 1:12 PM
    TinyInkognegroT
    https://youtu.be/W0POgyonu74
